Picture request on staggered rims for X sedan
Old Apr 11, 2009 | 09:34 PM
  #31
G35xQX1's Avatar
just take a peek in my "garage" i ran the staggered G37S coupe wheels on my X for 7 months last spring through fall without a problem. keep in mind though, i was running 245/40's all around = same rolling diameter.
on my Volks this spring, I decided to be safe and run not staggered ie 8.5 all around.
and to be honest guys, it's the OP's car and his decision whether to run staggered or not as he will be the only one driving the car and ponying up the money if something does fail.
but here is something to bake your noodle a bit. if nissan says that running staggered is bad for the X, then why the heck did they provide a skinny as hell spare tire? and yes i know that the spare isnt meant to be driven on for that long but still. something to think/ debate about
Old Apr 11, 2009 | 11:48 PM
  #32
EWG35's Avatar
You can buy custom wheels which are actually the same width and offset and you can run the same size tire, but have a different lips front and back. They basically cut the mounting pad (which mounts to the hub) thinner then mount the spoke to the rim in a more inward position. You will have the look of an staggered wheel but no AWD problems because all the measurement are the same.
Old Apr 12, 2009 | 03:59 AM
  #33
aooooo's Avatar
this is the 2nd time im running staggered. last yr i ran g37s and this yr the vossens. so far so good
Old Apr 12, 2009 | 05:42 AM
  #34
Ant0n's Avatar
Originally Posted by Pdubz
i got a 07 g35x with staggered set up.. so far nothing is ****ed up. i've been riding on these for a month now. tranny is fine.
that's it!! Thnx a lot for the pic! What tyre size are you running?
Old Apr 12, 2009 | 05:43 AM
  #35
Ant0n's Avatar
same for you bro, whats the size of your tyres? did you keep the same/close diameter of the tyre?
Old Apr 12, 2009 | 05:44 AM
  #36
Ant0n's Avatar
although its gonna cost more $$$, thats a good idea.
Old Apr 12, 2009 | 09:11 AM
  #37
sunny G-35 NYC's Avatar
yo if you want to run staggered wheels and tires do it not a problem. You would appreciate the info you find on this site instead of calling people retarted and stupid that's
Plus why are you even arguing you don't have an AWD G it says in your sign
Old Apr 12, 2009 | 01:33 PM
  #38
aooooo's Avatar
37s were stock so wateva the stock diameters are with 225 in the front and 245 in the rear
my vossens are 9.0 in the front and 10.5 in the rear =)) wit 245s and 285s
Old Apr 14, 2009 | 05:38 AM
  #39
Ant0n's Avatar
oh ok! thnx a lot for the info
Old Apr 21, 2012 | 05:49 PM
  #40
Scooter1's Avatar
I have a 2007 g35x sedan looking to run 8.5 up front and 10's int he rear 20 inch what size tires do i have to run
Old Apr 22, 2012 | 09:19 PM
  #41
k7G35x's Avatar
here you go scooter: https://g35driver.com/forums/media-s...ml#post6422719
I ran staggered wheels all last summer with no issues at all! The summer tires are back on and now lowered with no issues yet this year. I say as long as the tires are the same height you will be fine with a staggered setup. Its not the same awd system as a subaru. Subarus are really picky you can explode your diff if you run tires with different amount of tread. I would never run staggered wheels on a subaru unless I got a BRZ...
Old May 12, 2012 | 11:34 PM
  #42
MPG35fiend's Avatar
INTENSE thread! Super informative......
ok now i need help on figuring out how to calculate rolling diameter on my wheel set up.
19x9.5+22
19x10.5+22
can i run a 235/35/19 front and 245/35/19 rear?
i would do the math but i don't know how??
PLEASE help me!
Old May 13, 2012 | 08:27 AM
  #43
Scooter1's Avatar
19x9.5+22
19x10.5+22
PLEASE help me!
Nope have to run 35 up front 30's in the rear
Old May 13, 2012 | 11:49 AM
  #44
surfjax87's Avatar
19x9.5+22
19x10.5+22
PLEASE help me!
I'm sorry but I will never understand the rationale for running these crazy offsets that require stretched tires and lots of camber to fit. But if you like it, then go for it. Here's the tire spec stuff. And here's a site to calculate all this stuff. http://www.1010tires.com/tiresizecalculator.asp
Old May 13, 2012 | 12:40 PM
  #45
MPG35fiend's Avatar
Ok Sweet!
So 235/35 in the front and 245/30 in the rear?
Or do you think 235/35 all around on19x9.5/10.5 would look better.?
