Stealth Trunk Lip Installed! (my very own creation)
Old May 23, 2009 | 10:57 AM
  #61
Wes_888's Avatar
Originally Posted by sammy_G
resin doesnt look like the problem... you gotta do A LOT of fine sanding to get the weave-finish out and creat a smooth surface finish. i usually start with 600 and then go to 1000,1200wet, and finally 1500wet.
I thought about sanding it. The reason why I didnt wanna sand it on my first try is because I want to provide maximum protection for the CF beneath the sealant. I also wanted to make sure you can still see the CF beneath sealant with a minimum amount of urethrane but maximizing protection.
Also I gotta keep in mind the adhesive holding the CF to the trunk. if I manipulate the CF too much, im afraid I might compromise the adhesive too and then the CF wont stick to the slip and fail.
Originally Posted by Gdrift
Use CF on the grille to create CF Midnight Grille! want to tackle this one? lol
Its funny, I thought about that. The urethrane wont do for the front cuz of stone chipping.
Now if I worked with resin, then perhaps.
Old May 23, 2009 | 05:07 PM
  #62
sammy_G's Avatar
adhesive?
i'm confused, did you use real carbon cloth? or the imitation carbon fabric? if it's the latter... don't try and sand it!!
Old May 23, 2009 | 06:50 PM
  #63
Borna's Avatar
Yeah he used carbon pattern fabric.
And yeah Wes don't sand it cause you'll ruin the fabric.
Old May 24, 2009 | 12:21 AM
  #64
Wes_888's Avatar
+1 hehe
yes it is fabric :P
Old May 24, 2009 | 12:36 AM
  #65
prelude555's Avatar
looks good on your car wes, but i think it does need a little smoother look to it so it'll look alot cleaner.
nonetheless still looks good, keep it up!
Old May 24, 2009 | 12:41 AM
  #66
Wes_888's Avatar
thanks =)
Its hard though.. to make it look smoother. But in person, it does feel smooth. Maybe in pics it looks rougher. But its quite allright in person =)
Old May 24, 2009 | 09:32 PM
  #67
Soni's Avatar
Wes, you are my hero!!
Old Jun 30, 2009 | 08:45 AM
  #68
Soni's Avatar
Wes, how the fabric holding with all the rains recently?
Old Jun 30, 2009 | 03:44 PM
  #69
Wes_888's Avatar
Hey Soni.. I actually changed it up!
https://g35driver.com/forums/media-s...-out-rear.html
Just cuz the opportunity presented itself not cuz I was unhappy with the CF.
For the most part, it held up nicely actually. There was just a small part of the material that came loose a lil bit.. but I think thats more related to the lack of adhesive that I sprayed at that part. But the material truly became waterproof. You have plans of CF'ing something on the outside of your car?
Old Jun 30, 2009 | 03:49 PM
  #70
Soni's Avatar
I just want to see what other option we have. I am looking into re applying adhesive on the back of the fabric.....will see what I can get from my supplier.
Old Jun 30, 2009 | 03:51 PM
  #71
Wes_888's Avatar
the adhesive in the interior of your car is coming off?
Old Jun 30, 2009 | 04:27 PM
  #72
InTgr8r's Avatar
Staff ALUMNI (retired)
I used a new kind of 3M when I repaired the door fabric in my daughters Civic.
It's MUCH higher temperature rated than the 77.
It's basically a spray contact cement.
You spray both pieces, let air dry, then put together.
You have to be careful assembling, but that stuff holds like crazy.
It's intended to be permanent.
It's something like 3M 90, but I'll double check the name when I get home.
I found it at Concord hardware, 9094 Leslie St. #6
Old Jun 30, 2009 | 05:55 PM
  #73
GEE35FX's Avatar
I know this isn't the place but if anyone wanted a 2nd Gen Chrome lip to paint or carbon fibre, I have my lip off my 2nd Gen that I would let go for a cheap price (PM me if you want it).
Old May 17, 2010 | 05:11 PM
  #74
ultraman1017's Avatar
check out mine https://g35driver.com/forums/g35-sed...-spoilers.html
Old May 18, 2010 | 10:46 AM
  #75
sameerg's Avatar
What wheels are those? Are those the coupe 18s?
