Tire help
Old Mar 10, 2016 | 07:54 PM
Kolokz's Avatar
Tire help
I just got wheels 18 8.5 and 18 9.5 and it comes with a spacer.. Just want opinions in what tires size to install them with.. Will lower my car with springs by h&r please help this is the rims i got
Thanks for you time
Old Mar 10, 2016 | 08:42 PM
DeafBringer's Avatar
Did you even bother to search the rim section?
Old Mar 10, 2016 | 10:39 PM
Kolokz's Avatar
Im new with this the what do u mean by rim section? Its a tsw rim 18x8 and 18x9.5 for the rear
Old Mar 10, 2016 | 10:47 PM
gtBMWatc's Avatar
https://g35driver.com/forums/wheels-tires-25/ he means this section. It is the rims and tires section of the tech section. Your question is probably answered in there. Good luck and nice rims.
Old Mar 11, 2016 | 12:26 AM
ScraggleRock's Avatar
At least 265/35 rear and 235/40 front, but probably better to go 275/30 rear and 245/35 for the front.
In either situation you keep the same rolling diameter (that way your speedo is happy) as stock but get a wider tire with the second option. If you wanna fill out the wheel well a little more, you'll have to look up how tire sizes work.
Old Mar 11, 2016 | 12:33 AM
Kolokz's Avatar
Thanks im goin to read.. Yeah its my firstime having a stagered rims excited to put them on..
Old Mar 11, 2016 | 01:04 AM
Kolokz's Avatar
Thank you boss.. Having that 265/35 on the rear..i will install my h&r springs how will the camber be will i need to put in camber kits? Or should i just keep the stock suspension?
Old Mar 11, 2016 | 01:52 AM
A camber kit is necessary even for stock suspension. Lowering it requires both a camber kit and toe bolts. Many people will say it's not necessary, but for proper alignment and tire life every G owner should add front camber adjustability (as well as rear adjustability and toe bolts if lowered).
Old Mar 11, 2016 | 02:48 AM
Kolokz's Avatar
Thank you for the info...
Old Mar 11, 2016 | 09:05 AM
VenomGT9's Avatar
275/30 is way too short for an 18in
Try 245/45 and 275/40 for 18s
bigc
20 Inch
May 21, 2016 06:20 PM
nineiron
Mar 24, 2016 10:28 AM
nicoG35
San Diego G35
Mar 22, 2016 01:51 AM
Michael Derka
Mar 21, 2016 10:48 PM
Tylko Kazik
Mar 10, 2016 08:53 AM
