G35s sedan 2007 water pump
Old Dec 8, 2017 | 05:24 PM
Merkleyp's Avatar
Hi there all,
My g35s sedan started making a bad pulley sound (kinda metallic sound) and fluttering sound like bad gas. I've been using premium 92 on it, but didn't make a difference. Noise only happens under load at about 3000 rpms. Now I have coolant under the rear of the engine block. Could it be the water pump going bad?
Also, if it is, is this a DIY'er, I'm not a mechanic, but i hold my own, I think. HaHa. I cant seem to find video specific for it.
Any advice, I would be in your debt.
Infiniti G35s Sedan. 3.5L Automatic 110K miles.
Old Dec 8, 2017 | 05:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Clean up the underside thoroughly, get the vehicle in the air, running, with a good light and inspection mirror and find the leak EXACTLY where it's leaking. Then you will know which component has failed and can proceed with a repair.
Old Dec 8, 2017 | 05:53 PM
Merkleyp's Avatar
I did that this morning and for the life of me I couldn't get a clear view, top or bottom, as to where it was coming from, but it starts condensing towards the rear almost under the transmission. When hot, it also smokes, but not too bad and the steam comes from next to the battery casing (passenger side). All fluids are good and the leak is green, but somewhat viscous. Its not overheating. I did have to put a half of gallon of water this morning, but that's the first time in months that i've had to top it off.
Old Dec 8, 2017 | 08:20 PM
cleric670's Avatar
BANNED!!!
Might need a bigger inspection mirror, sometimes the tiny little round one isn't big enough and you need the bigger rectangle one.
HotRodG35
Engine - Intake/Fuel
Aug 31, 2013 04:25 PM
ajg35
13
Jan 7, 2008 12:51 PM
RussianG35
Nov 2, 2004 03:18 PM
