Kid hit the curb... Right Side - Passenger Wheel
Old Nov 13, 2018 | 05:29 PM
G35-Brownie's Avatar
G35 Sedan
So my son rashed the wheel by hitting a large curb. Now his G35 - 2004 pulls hard to the right. I had a local person look at it. He said both upper and lower control arms, along with the possibility of the strut needing to be replaced. So I started by replacing the lower control arm with a new one. No change... in the pulling to the right. The steering wheel is also crooked/tipped to the right. SLIP light is now on. When I measured the distance between the rear part of the fender and the tire. It looks to be closer on the damaged side by about a 1/2 inch. I have an appointment with another shop for a second opinion. Just new to the site so wanted to toss it out... Any thoughts on what all could be messed up? Kids! LOL...
Old Nov 13, 2018 | 05:32 PM
herrschaft's Avatar
Pics of the damage would help
Old Nov 13, 2018 | 05:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like something bent, get measurements of the front subframe brace and look for anything bent. Could be anything. A reputable alignment shop can probably spot the problem in seconds.
Old Nov 13, 2018 | 09:21 PM
onevq35de's Avatar
Hit the curb on the opposite side about as hard. That oughta do it.
Old Nov 14, 2018 | 12:25 AM
Silversleeper86's Avatar
G35 Sport Sedan 5AT
Well, your lower control arm is new. So, that leaves the upper + strut + hub + sway bar and steering rod/tie rod. If the subframe has shifted that can be hard to spot by just looking, but otherwise best thing would be to get under there and do exactly that...look. If you're not used to knowing what things look like then take both front wheels off and compare
Old Dec 3, 2018 | 05:04 PM
G35 Sedan
Just wanted to update everyone. It turned out that the lower control arm and the rearward control arm was bent. After we replaced them, then we were able to do the alignment. So that was good news! It ended up costing about $100 in parts and $75 alignment.
Old Dec 3, 2018 | 08:21 PM
Urbanengineer's Avatar
Awesome!!!
BabySkyline
Jul 17, 2015 06:05 PM
dh2225
Jan 8, 2014 07:13 PM
yoyopol2000
Mar 9, 2007 01:30 PM
Corgidog
Aug 8, 2005 10:38 PM
