Shifting a lil wierd
Old May 2, 2020 | 12:29 PM
Horacio Perez's Avatar
Awd
Hi everyone i have a g35 2004 with almost 300k & i notice that after ive been driving for a while when im coming out a stop or on a turn when i dont completely stop it shifts kinda jerky sometimes it even feels like someone bumped me from behind... The fluid is fine i got & no check engine light & it runs fine other than that lil issue... Any idea what it might be???
Old May 2, 2020 | 12:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
First inspect the driveshaft u-joints and carrier bearing for wear, then check the rear diff input shaft/ring gear for play.
Have you been keeping up on transmission fluid changes?
At 300k there's a LOT of parts near failure so it could be quite a few things, gotta get the car up in the air and start looking.
Old May 2, 2020 | 12:46 PM
Awd
Thank you
As far as i know fluids have been keeped up.. I have 50 50 warenty so should i take to dealer & tell them check all those things?? Also is it wierd there is no check engine light? & should i have them look @ timing belt? Thanks
Old May 2, 2020 | 01:06 PM
cleric670's Avatar
BANNED!!!
There is no timing belt it's a timing chain and it wouldn't be causing jerky shifts.
Actually I bet I know what it is, your rear differential bushing is probably 100% shot. Maybe even missing big chunks out of it. You can look up under the car with your phone and take a picture to see if it's missing large chunks, if it's the OEM rubber bushing they're usually pretty shot by 60k miles, I imaging by 300k there's probably nothing left.
Most folks replace them with a polyurethane bushing.
Old May 2, 2020 | 03:19 PM
Awd
Thank you
So thats under the rear wheels right?? Also can u tell me why this only happens after i have been driving abou 30 to 45 min? Thank you god bless u sorry i just know nothing about cars
Old May 2, 2020 | 06:33 PM
cleric670's Avatar
BANNED!!!
Yeah it's the rear differential, that's basically the big round part in the middle hanging from the subframe cradle. It might not be the issue but it's a common failure point on these cars however it shouldn't make any difference in how long long the vehicle has been operating.
I suggest you take the vehicle into a reputable mechanic for a diagnostic before something actually BREAKS. That way you can schedule the repair on your own time instead of being stranded on the highway waiting for a tow truck.
Old May 3, 2020 | 01:57 PM
Awd
Hi
Hey is there 2 of those one under each tire?
Rob G37S
Feb 27, 2020 07:10 PM
Touge_All_Day
Jan 6, 2020 06:19 PM
Ala 89
Dec 17, 2018 10:24 PM
snunez
Oct 27, 2018 03:29 PM
Blue100
Aug 18, 2018 11:42 AM
