help with transmission
Old Jul 23, 2020 | 05:07 PM
jaime siavichay's Avatar
g35 coupe
hey guy sorry im new here... well I need to change the automatic transmission for a 2004 g35 I wanna revive my old car. I found a good transmission but those it need to be reprogram after the change or will be good after the swap 🤔 😕
Old Jul 23, 2020 | 09:20 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Make sure you are getting the correct transmission. 2003 to Early 2004 cars have the TCM in the passenger side lower kick panel, Late 2004 and on cars have the TCM inside the valve body of the transmission. You can verify by removing the kick panel:
As far as I know, late 2004 cars you have to take the car to Nissan/Infiniti to have the TCM and ECU 'married'. Not sure about the earlier cars...
Old Jul 24, 2020 | 06:08 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you have the early style car with the TCM mounted in the cabin next to the ECM then you definitely don't need to get anything reprogrammed.
If you have the later style with the TCM inside the transmission then word on the street is you don't need to get it reprogrammed if it was a USED transmission but you will need to get it reprogrammed if it's a NEW transmission.
Old Aug 2, 2020 | 08:30 AM
g35 coupe
Is gonna be a transmission from other g35 not new is been used so doesn't need reprogramming??
Old Aug 2, 2020 | 08:32 AM
g35 coupe
yeah my ia insde the transmission since I change the solenoids cuz they gave the code but after that keep coming the same code and the csr lost power and transmission light came on the dashboard
if u see the reply after this one guy says if is a used I dont have to reprogrammed!!!!! Also if I dont reprogrammed what will be the issue.... are they gonna be present immediately
Old Aug 2, 2020 | 02:48 PM
cleric670's Avatar
BANNED!!!
Exactly what code is the car throwing?
Old Aug 2, 2020 | 04:38 PM
g35 coupe
P1762 Direct clutch solenoid valve
all solenoids were replaced and tracks were check for continuity
Herb43
Oct 12, 2019 06:31 PM
