*need help quick*
*need help quick*
Hello, I have a 2007 infiniti g35 with 100,000+ miles that needed a new valve body. I got one locally and installed it. Then I found out that you had to program the tcm found in the valve body so I paid someone to program it for me but then discovered that my car has 0 throttle response and doesn't respond to reverse or drive but it shows up on the dashboard.
can you guys help me pleaseee?!?
Sounds like they didn't program it, this requires Consult-III which is the dealership tool.
You can always just take the existing TCM and use it on the new valve body, that way you know it's going to work.
However if they DID clear the TCM information from the ECM then it's still not going to work.
You program the ECM to recognize the TCM.
