Automatic transmission swap g35 2003
Old Feb 20, 2021 | 09:53 PM
Ronbowman49's Avatar
Infiniti G 35 I think it’s fully loaded I just received it
I change my transmission from automatic to manual and now it still doesn’t see it on the computer is there a certain computer I need to get what part number
Old Feb 21, 2021 | 01:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You need to rewire the ECM for the park/neutral switch being in a different location. Google search "g35 5at to 6mt swap" and you should find what needs to be changed.
Old Feb 21, 2021 | 01:46 PM
cleric670's Avatar
BANNED!!!
Or are you saying you cannot connect to the ECM with an OBD2 scanner? Sort of hard to tell what you're actually asking.
Old Feb 21, 2021 | 03:45 PM
Tranny swap
The tranny‘s in everything’s working except the service light goes on after 10 miles it’s not reading the automatic transmission because it’s not there RPMs work mileage works
Old Feb 21, 2021 | 08:25 PM
cleric670's Avatar
BANNED!!!
Exactly what code is it throwing?
Old Feb 22, 2021 | 10:19 PM
That’s a good question let me get back to you
Old Jun 1, 2021 | 10:24 PM
g35 2003 Tranny swap
The code it’s popping is P0 720 VSS signal circuit fault
Old Jun 2, 2021 | 05:39 PM
cleric670's Avatar
BANNED!!!
I think that's the sensor in the tailshaft housing. It plugs in separately to the board, it's cable needs to be unplugged before you can remove the valve body.
Old Jun 2, 2021 | 05:42 PM
cleric670's Avatar
BANNED!!!
Ohh wait, you did a 6MT swap. That code doesnt exist on the 6MT cars it's a 5AT code I think.
Old Jun 3, 2021 | 12:25 PM
Yes I went from an automatic to six speed manual transmission
