I'm new to this forum, thank you members and admins! Need some help, thanks in advance. 👍
We have a 2007 G35 coupe and the nozzle housing for the windshield wiper fluid on the driver's side broke away from the wiper arm. I called an online parts dealer and was told that the housing is part of the arm on the 07' and the entire arm needs to be replaced. Have you dealt with this issue and did you find a replacement housing, or did you replace the entire arm? The MacGyver fix is ok, but I'd like something more permanent.
I would superglue, epoxy, JB weld that thing back into position. If you need a picture of the location for it I can go take a pic of my 2006 coupe tomorrow, should be the same.
Good point about the additional broken piece. I was lucky enough to find an entire right and left assembly (minus blades) on eBay for $60, pulled from a 2007 G35 Coupe. Lucky find.
