Electrical wire plug from MAF Sensor
Old Jan 18, 2022 | 06:58 AM
Isela Herrejon's Avatar
Slammed coupe on 20's.
Need Help Again!! Which wire goes with which? I'm so confused. Should I solder the wires together or not? 2004 G35 coupe.
These are the wires from my car.
MAF Connector
Old Jan 19, 2022 | 03:25 AM
Scorpi0's Avatar
Didnt we already answer this thread a few weeks ago?
Old Jan 19, 2022 | 10:09 AM
Yes! So I printed all the info you guys provided for me. I gave my mechanic the info. So this whole time I thought he was working on it or job was completed.I was in no hurry to get my car back. Anyways, long story short. My mechanic passed away on 1/3 from Covid. So I decided to bring my car home. I couldn't. He never got around to working on my car. I don't have the means to have someone do the job. So now I wanna try and figure this out myself. The colored wires on the
pigtail are different from the wires on my car.
Old Jan 21, 2022 | 12:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Here's the schematics again.
Old Jan 21, 2022 | 12:38 PM
cleric670's Avatar
BANNED!!!
So on the F39 harness, if you are looking straight at the harness with the locking tab facing up, it should be left to right (pins 1 - 6)
1Blank, 2Pink, 3Black/white stripe, 4Orange, 5Yellow/green stripe, 6Blue
It doesn't matter what color the wire is on that pigtail, just make sure the correctly corresponding engine wiring hooks up to the correct pin on the pigtail.
Old Jan 21, 2022 | 12:41 PM
cleric670's Avatar
BANNED!!!
And yes you need to solder those connections, if you aren't comfortable soldering you can buy "solder splice" connectors that have a little bit of solder already inside the shrink tube. Use a heat gun, not a lighter, for the best results, a hair dryer doesn't get hot enough.
Old Jan 22, 2022 | 03:31 AM
Thank you! I'm gonna try and connect them tomorrow. I appreciate your reply. 😊 If I have any more questions will it be okay to reach out to you?
Old Jan 22, 2022 | 11:21 AM
cleric670's Avatar
BANNED!!!
Just ping me with @cleric670 in this thread, it makes my phone beep so that's the best way to get ahold of me. Make sure to actually pick my name in the little dropdown box after you type that in though, once the font changes and my link is embedded I'll get the ping, just simply typing @ my name without actually SELECTING me from the list won't work.
Old Jan 24, 2022 | 10:07 PM
cleric670's Avatar
BANNED!!!
Replying the this post because I'm on my phone not my PC.
Here's a screenshot of your pm to me with wire colors.
Old Jan 24, 2022 | 10:13 PM
cleric670's Avatar
BANNED!!!
Pin1, Nothing on the blank pin obviously.
Pin2, your car pink wire to pigtail grey2
PIn3, your car black/white stripe to pigtail light green
Pin4, your car orange to pigtail grey4 (one of those two grey wires is probably a different color or has a stripe btw).
Pin5 your car yellow/green stripe to pigtail green
Pin6, your car blue to pigtail yellow
Old Jan 25, 2022 | 04:07 PM
I did it!!!
My car started!! THANK YOU SO MUCH. 😊😊😊
Old Jan 26, 2022 | 08:09 AM
cleric670's Avatar
BANNED!!!
Awesome, glad everything is all sorted out.
Old Feb 6, 2022 | 05:51 PM
Knock! Knock!
You there?? I need HELP AGAIN,LOL
Old Feb 6, 2022 | 09:42 PM
cleric670's Avatar
BANNED!!!
Yeah what's up?
Old Feb 6, 2022 | 11:06 PM
Scorpi0's Avatar
Damn Cleric, If u had a tip jar you’d be rich.
