2003 G35 Rear Axle Nut - Tighten With Vehicle Raised or Not ?
Old Aug 28, 2022 | 12:06 PM
Jebiga's Avatar
G35 Sedan
Just replaced passenger side rear hub and wheel bearing assembly. What a grunt getting to the 4 holding bolts and hammering the rusted in assembly off. Anyhow, the loud whirring noise is now gone so it was the wheel bearing going bad. I had the right side jacked up using the suspension (not on rear diff). I then tightened the axle nut but it seemed to go a lot further this time past the cotter pin hole to remove any axial movement in the CV. Lowered car and went for a drive. Should I tighten the axle nut with the car lifted and no stress on suspension ? (Raised using differential) or tightened with car on ground and load on suspension ? Also to what torque setting for 2003 G35 Sedan ? Thanks in advance board !
Old Aug 28, 2022 | 01:47 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
CV axle nut it doesn't matter whether the suspension is loaded or not. Usually I just stick a screwdriver into the vents of the brake rotor, jam it up against the brake caliper, and tighten the nut without the wheel on.
Rear CV axle nut torque is 152-202 ft/lbs. I normally go for the higher end of that range, 180 to 200 ft lbs.
Old Aug 28, 2022 | 01:58 PM
Jebiga's Avatar
G35 Sedan
Thanks Cleric !!
Old Aug 28, 2022 | 05:59 PM
cleric670's Avatar
BANNED!!!
Here's how to place the screwdriver.
Old Aug 29, 2022 | 11:23 AM
Jebiga's Avatar
G35 Sedan
Same effect with leaving it in gear or on the ground correct ? My G35 is a six speed manual.
Old Aug 29, 2022 | 01:19 PM
Jebiga's Avatar
G35 Sedan
Old Aug 29, 2022 | 04:58 PM
cleric670's Avatar
BANNED!!!
Yep, except sometimes the wheel doesn't allow for a large enough socket. Not sure about the factory ones.
Teddy Maze
Nov 8, 2020 12:19 PM
ThatWasSketchy
Sep 29, 2020 01:48 PM
ResoG35Sedan
Oct 20, 2008 05:33 PM
