Spark plugs
Old Feb 8, 2023 | 04:45 PM
951suspect's Avatar
Basic stock
Spark plugs
Hey guys I have a question, can you use Bosch Double iridium spark plugs on an Infiniti G35, or are NGKs better recommended?
Old Feb 10, 2023 | 12:17 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I always recommend stock plugs for the G35 unless you have some kind of forced induction.
DE engine is the platinum NGK PLFR5A-11
HR engine is the iridium DENSO FXE22HR11
If you really want to run an iridium plug in the DE engine then use the NGK LFR5AIX-11 but I don't think it's necessary at all, especially considering the DE engines usually drink oil so you're going to crap out the plugs before you actually wear them down once the engine is over 75k miles on stock piston rings. If your DE never drinks any oil over the 3500 mile oil change interval than the iridium NGK would be fine.
Old Feb 13, 2023 | 10:37 AM
Urbanengineer's Avatar
If you really want to run an iridium plug in the DE engine then use the NGK LFR5AIX-11 but I don't think it's necessary at all, especially considering the DE engines usually drink oil so you're going to crap out the plugs before you actually wear them down once the engine is over 75k miles on stock piston rings. If your DE never drinks any oil over the 3500 mile oil change interval then the iridium NGK would be fine.
It’s weird that Vortech says to just run stock plugs imo.
Old Feb 17, 2023 | 09:58 AM
cleric670's Avatar
BANNED!!!
350ish WHP stock plugs would be fine, if you're pushing up to 400 WHP it's probably time to gap them down to like .035 and pull them at the first oil change to make sure they're burning clean.
Experiment with a colder plug, if they're starting to get carbon fouled then it's too cold.
It takes a LOT of extra heat to melt a plug, it only takes a little less heat to foul a spark plug, probably why Vortech recommends stock heat range.
R M
Oct 10, 2017 01:31 AM
Driftnh
Dec 9, 2015 05:46 AM
