G35 misfiring/leaking oil
Old Jul 27, 2023 | 07:41 AM
Alexthered23's Avatar
Needs a lot of work and I mean a lot but I love it!
Hello everyone I’m new on here and need some help. My car was running rough as hell so I cleaned the maf sensor. Change my intake, changed oil , and changed spark plugs. But now car is misfiring and leaking oil out of the rear passenger side of the engine I’m not sure where it’s coming from? But it’s dripping on the downpour if that help. Also have the PO300 check engine light. Which is why I changed everything I did. Thank you for your time anything is appreciated!!!
Old Jul 27, 2023 | 10:21 AM
Urbanengineer's Avatar
Could be the passenger side valve cover gaskets going bad. Probably time to replace the oem covers with some aftermarket ones (with oem gaskets)!
Old Jul 27, 2023 | 12:49 PM
Can you change them from the top or does the whole engine need to be pulled? I can’t see any oil on top side of engine bay.
Old Jul 27, 2023 | 01:05 PM
Scorpi0's Avatar
The misfire might be because you mixed up the #4 and #6 coil pack wires when you changed the spark plugs. The way the wires are oriented, its easy to mix them up. Its happened to a lot of people, myself included.
Old Jul 27, 2023 | 01:06 PM
thank you. I will have to check when I get home. Didn’t think about this.
Old Jul 27, 2023 | 03:27 PM
this wasn’t the problem. Still don’t know.
Old Jul 28, 2023 | 12:33 PM
Scorpi0's Avatar
So u mixed up # 3 and 5 coil wires huh?
Old Jul 28, 2023 | 06:44 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get an inspection mirror and a flashlight and just look around for where the oil is pouring out. Might have a cam sensor came loose and it's just pouring oil out of the hole.
Old Jul 28, 2023 | 08:50 PM
Yes I did. Now the leak of oil is way slower almost not noticeable. But car feels weak so I don’t know what it could be. No codes are being thrown now. How should I go about the power issue?
Old Jul 28, 2023 | 08:51 PM
I ordered a endoscope so I will know soon
Old Sep 4, 2023 | 08:09 AM
BernardWilliam's Avatar
suv
Amaria
Jan 13, 2023 01:33 PM
Datboiwithda350
Aug 18, 2022 10:44 PM
Rollmachine
Feb 3, 2018 03:51 PM
Jonconusaf
Dec 26, 2015 01:31 AM
