Help with check engine light -2007 G35 coup auto 150K
Old Mar 7, 2025 | 03:24 PM
Kramnamtip's Avatar
OEM Infiniti G35 coup automatic
I have had a check engine light that would come on ever 90 to 100 miles with a p0021 code. I would turn it off and drive another 100 miles since it's only my weekend car and it would last about a month. Every once and a while a battery code will come up and sometimes a vehicle speed sensor code but not all the time.
With the nice weather I decided to replace both vvt solonoids thinking that would correct the issue but I only made it to approx 120 miles and I got the p0021, p1721 vehicle speed sensor, and c1109 battery voltage codes.
I monitored the voltage and every few seconds the voltage running drops to 13.5 to 13.8 volts.
Do you think this is a alternator issue or something worst? Car always starts but every once and a will it will have a long crank about once a month.
My gauge cluster is failing or I think it is because the battery and break light above come on lightly some times but if you hit the dash they go out. I just wanted to state this.
S4BrFalse
Jun 10, 2023 06:52 PM
Santi612
Jul 5, 2021 12:18 PM
Rob G37S
Feb 27, 2020 07:10 PM
snunez
Oct 27, 2018 03:29 PM
PhonkyG35
Jul 27, 2016 11:59 AM
