Passenger Side Window Problem
Old Aug 22, 2010 | 11:48 PM
Frankieg35's Avatar
Originally Posted by G35Ian
Do not go to autozone for a window motor...I can not stress that enough!!!
This is a common problem, I had the same problem with my G. There is a simple fix to this problem, Are you good with your hands? If you are all you need to do is remove your door panel, take the window motor off the regulator, remove the cover from the motor and clean the brushes in the motor. Then put it back together and your good to go.
If you have any questions just pm me or email g35ian@gmail.com
Ive done that and it worked for a week and starting fawking up again.. Guess i need a new window motor..
mbe093
Lights
Oct 2, 2016 11:09 PM
xluke
Jul 30, 2016 01:48 PM
neight
Aug 2, 2015 03:01 PM
wylin
Lights
Jul 18, 2015 06:12 PM
