Maintenance / Repair Help
#91
on
I don't know if I need a tranny flush, I heard a simple drain & fill is all you need around 50-60K. My car has 53K on it so I'm doing most of the 60K service. I can definatley take it into a shop for the tranny fill if needed, but if you could help me with the belts and radiator service that would be awesome. What do I need for the radiator service? Do you think plugs at the 60K service?
#92
Plugs at 60K isn't a bad idea at all. The plugs are speced for 100k miles but swapping them out for fresh ones will only help your ignition system. For the radiator service you'll need some oem coolant and some distilled water. I would probably buy 2 gallons of coolant and 2 gallons of distilled water (typically that's how much is needed when doing a cooling system flush, but a drain and refill should be similar). You might consider replacing the thermostat too as preventative maintenance. I'd swap out the pcv valve too and drain and refill the differential as well.
#94
OK. I'll wait on the plugs untile I get a my plenum spacer, then I'll do them at that time. The radiator flush sounds good, PCV valve is easy, and hopefully the belts aren't too hard. What exactly is involved with the differential drain/fill? Thanks for the info.
#97
#98
New G35 Owner
I bought a G35 about 6 weeks ago and had a question about the maintenace schedule. Most of the miles (99%) on it till now are on the interstate and this will be the case for the next year.
Considering this, is it a good idea to opt for the 7500/15000/22500--maintenace schedule that the owner's manual talks about? Or should I stick to the regular 3750/7500...schedule.
thanks in advance for the suggestions.
#99
#101
#102
Originally Posted by cloud
hey bythabay, do you buy any chance have a lb/in torque wrench? I suspect a vacuum leak (plenum / MREV+) but I don't exactly know how to fix stuff cause I got my MREV installed at ZCG.
first, several of the plenum bolts were actually loose! is this something that happens often? Perhaps others should double-check their install?
second, I successfully flushed my brake fluid today using my recently aquired motive power bleeder. I flushed 2 quarts of synthetic dot 4 brake fluid through my system - braking seems improved (at least the feel of it does)
#103
hi everyone,
man, i think im one of the only chicks on this thing, but anyway... i have an '05 coupe "bone stock", and just do day-to-day driving. does anyone else have problems with those stupid tire pressure sensors going off a little too often?? MINE WENT OFF AGAIN TODAYY!! i checked all my tires "BPI" (or whatever), my rear left was at 28, my two fronts were at 29 and my rear right was at 30. any remedies? i think frontier infiniti on stevens creek is tired of seeing me. thanks in advance for any suggestions/advice!
#104
Originally Posted by ShannieShan78
hi everyone,
