Fog Bulb Replacement!
Old Dec 14, 2006 | 04:27 PM
dcityjatt's Avatar
Hey guys,
Just ordered my fog lamp bulbs (GP Thunder 8500K H1 Xenon/Plasma Quartz Ion Bulb 55W) to match the white headlights!
I have an 06 Coupe, and was wondering if any fellow generous g35 drivers who have done this in the past, and would be willing to offer me help in putting these on. if not, can you please suggest where can i get it replaced for cheapest I live in fremont
thanks!!
Old Dec 14, 2006 | 06:38 PM
Mike_Deezy's Avatar
just peel back the fender lining and replace it yourself.
Old Dec 14, 2006 | 07:20 PM
dcityjatt's Avatar
yeah, i read up the DIY on this. I am afraid i might mess up!! Just wanted to avoid that. any help guys?!
Old Dec 14, 2006 | 07:47 PM
Mike_Deezy's Avatar
it's really straight forward, you can't mess up anything. Just be sure not to touch the bulb, other than that, you'll be fine.
Old Dec 14, 2006 | 07:56 PM
Hi-TechG35's Avatar
It's easy. Jack your car up and take off your front wheels (you should if this is your first time doing so). Afterwards take a small flathead screw driver and take out all of the black clips that hold in the splash shields. You will alsp need a philips head screw driver because one of the clips are held in by a phillips screw. After removing the clips and pulling the splash sheild back unscrew the cap that houses the bulb and unplug. Stick your replacement bulb in and you are all set. Also do not touch the glass art of the bulb, any grease or dirt particles could blow your bulbs.
Good luck on your install drop me a pm if needed.
Freddy07g35
Sep 17, 2015 08:53 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
