Help reading pinout diagram
Old Oct 4, 2007 | 02:29 AM
bertmauricio's Avatar
I'm trying to tap into my 07 sedan's bose amp wiring to run another amp and just need the high level speaker lines.
Someone posted a connector diagram and I just need to figure out if the diagram is based on looking at the connector from the contact side(flat side) or the wire side(where the wires enter the connector). My guess is the contact side but I've been known to be wrong.
Here's the diagram.
Thanks.
Old Oct 4, 2007 | 10:27 AM
V35 Skyline GT's Avatar
6MT Coupe
Not an expert by any means, but I'm going to guess its the side the wires go in.
My lodgic around that is, when you look at fuse box diamgram for example, the reference side is where the fuses go into the connection points.
Maybe someone in the 'audio' section would know for sure.
https://g35driver.com/forums/audio-video-electronics-20/
G/L
Old Oct 4, 2007 | 01:47 PM
Good point. Thanks G/L. I'll check in the Audio forum.
Old Oct 10, 2007 | 02:42 AM
Turns out the diagram is viewed at the connector as the wires go into it. Anyone with a 2007 Sedan w/Bose should tap into pins 31 RR(+)light green and 32RR(-)yellow if you need a high level input.
Set your gains and it actually adds just the right amount of thump to the stock head unit. I can still control the bass though the headunit and it sounds much better than stock...at least listening music on my ipod.
Here's a pic.
I know, I don't need the cap but it looks better here than stored away in my garage.
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
master111
Oct 6, 2015 01:36 AM
AL8782
Oct 3, 2015 10:26 AM
Learned Hand
Oct 1, 2015 09:02 AM
