squeaky brakes in bay area
Old Dec 11, 2008 | 01:57 PM
shaf140's Avatar
Is there anyone in the bay area that has resolved the squeaky brakes issue on 03 Coupes? I know there are plenty of threads on this forum about how to fix it and what brakes can be used for replacements.
I had my brakes and rotors replaced about 6 months ago and they have been squeaking ever since. I had it done at a brake and tire place and have brought it back in like 4 times and just gave up since they werent able to fix it.
I was hoping that the squeaking would get better as the pads got more wear on them but it doesnt look like its happening. The brakes basically squeak every day but I sort of just ignore it since I am so used to it and just blast my stereo. At this point I am thinking of just getting rid of this car and getting a Mini Cooper but in order to sell my car, I would probably need to get the brakes fixed first.
So if anyone in the bay area knows of a place or knows someone that has had experience fixing this issue, please let me know.
Thanks
-Alex
Old Dec 11, 2008 | 02:11 PM
Kris79's Avatar
battle froggy
sedan coupe? brembo non brembo? what kind of rotors and pads did you get installed?
Old Dec 11, 2008 | 02:23 PM
mpp_us2003's Avatar
same experience over here. 03' coupe. my car also vibrates a little bit when theres a high speed braking. i realized the rotors are so uneven that cause the vibration, but not sure if that also make the noise. im getting my rotors replaced this weekend. i will let you know if thats the case.
Old Dec 11, 2008 | 02:32 PM
shaf140's Avatar
they replaced it with OEM pads and rotors non Brembo.
2003 Coupe
Old Dec 11, 2008 | 02:33 PM
Kris79's Avatar
battle froggy
the noise is most likely bad break in or crapy pads if they rotors and pads are new.
edit from you rnew post imma say bad break in. what part of ssf you from?
Old Dec 11, 2008 | 02:35 PM
shaf140's Avatar
after the first time, they replaced the pads again thinking it was bad but still same issue.
Old Dec 11, 2008 | 02:39 PM
Kris79's Avatar
battle froggy
are you sure they used oem pads and oem rotors? did they reuse the shims?
Old Dec 11, 2008 | 02:40 PM
shaf140's Avatar
they said they did at least.
=P
Old Dec 11, 2008 | 06:59 PM
V35 Skyline GT's Avatar
6MT Coupe
Anti-squeal grease between pad and calipers....
Old Dec 11, 2008 | 07:03 PM
Deftronix's Avatar
Kris has got you covered since he uses grease on all his brake installs
Isnt, it between the shim and the pad? I dont think you want to be applying any lube directly to the rotors
Old Dec 12, 2008 | 08:05 AM
6MT Coupe
Originally Posted by Deftronix
.....Isnt, it between the shim and the pad? I dont think you want to be applying any lube directly to the rotors
Never said rotors...never grease between pad and rotors haha.
I'll be more descriptive I guess...between caliper piston and pad. If shims used, butter them up too.
Just noticed mine starting to squeal with ~35K on them on these cold mornings. Then no more after a few stops.
Old Dec 12, 2008 | 11:47 AM
Deftronix's Avatar
Haha sorry John I think i shoudl read a little more carefully before I decide to comment on something. Didnt read it right.. my bad haha
Old Dec 13, 2008 | 01:27 PM
6MT Coupe
It's all good Steve. When I read your response I scratched my head thinking huh...
Old Dec 15, 2008 | 02:50 PM
shaf140's Avatar
so kris helped me try to fix the pads yesterday but he found out that the pads were not OEM. mechanic also only used one set of shims. Kris lubed it up some more and clipped the one shim on each of the front. the car doesnt squeak as much but it still squeaks when i brake on the freeway at a higher speed. i am going to just have him replace the pads. hopefull that will fix it.
Old Dec 15, 2008 | 02:51 PM
Kris79's Avatar
battle froggy
endless vita nuova ftw!
