G35 Ecu Tuning
Old Jan 20, 2009 | 02:06 AM
bombapinoy's Avatar
G35 Ecu Tuning
Does anybody have an idea where I can get the ECU tuned around San Francisco area or around Fairfield area? I recently put a motordyne lower plenum and a spacer and now I'm running a bit lean. I really need this tune because i know how much wear it does on the engine. PLEASE HELP!!!
Old Jan 20, 2009 | 02:12 AM
SxExCx's Avatar
you shouldnt need a tune after just those mods. Check for leaks.
Old Jan 20, 2009 | 02:21 AM
bombapinoy's Avatar
I already had it checked by infiniti and there are no leaks. I mean...the engine runs fine and the mechanic says that it runs a tad lean but is able to run just fine...he also advised me to get a tune up and add more fuel the engine so that it won't run lean at all. Also i heard a tip that its better to run a little rich. The only thing is that it burns more fuel. But i really want a tune up.
Old Jan 20, 2009 | 02:34 AM
stillmatic's Avatar
Get the Osiris tune from EIP Racing in San Jose. They used to be a sponsor on here but I'm not sure what happened. At one point they were charging $500 to get the software/cable and 3 dyno runs.
Old Jan 20, 2009 | 02:37 AM
bombapinoy's Avatar
Do i need anything? Because it says access port for cobb tuning. Do i need anything for my Ecu? or do they just straight up tune the ecu?
Old Jan 20, 2009 | 02:54 AM
stillmatic's Avatar
No, Osiris is totally different from Cobb. Go to www.uprev.com and do a search for Osiris on here to get a better understanding.
Old Jan 20, 2009 | 06:24 PM
35gsleeper's Avatar
EIP Racing is great in San Jose..I took my car there in May 2008 and they had it for two days..search for my results by typing in EIP racing in the search menu..I made great gains off my first run..All u need to do is drop the car off and be patient..
Old Jan 20, 2009 | 06:56 PM
bombapinoy's Avatar
How much did it cost you? And did you have like cobb tuning or just the stock ECU?
Old Jan 20, 2009 | 07:09 PM
35gsleeper's Avatar
I had the stock ECU and I want to say it ran me $500.00 but they were running a good special..that was Orisis Uprev..with 3 runs..I also had my Headers installed there..great Job!
Old Jan 20, 2009 | 07:17 PM
matthimself's Avatar
would there be a point for this in a stock car?
Old Jan 20, 2009 | 07:52 PM
35gsleeper's Avatar
No! The ECU upgrades are mostly for N/A or FI cars. Allowing you to better match you A/F ratios so that you dont burn more fuel...waste gas!
Old Jan 21, 2009 | 04:13 AM
bombapinoy's Avatar
But in my case i need to add more fuel to my engine because i am running lean.
Old Jan 21, 2009 | 11:08 AM
DEMoLITIoN's Avatar
Fine Line Imports in Santa Rosa, CA. They do great work and they let you watch the whole thing. You dont need to buy anything. They flash it using Cobb software. Really great price.
Old Jan 21, 2009 | 12:50 PM
35gsleeper's Avatar
Bombapinoy u should do it! I was referencing to matts log..
Old Jan 21, 2009 | 02:04 PM
bombapinoy's Avatar
i will once i have the money. its just that i have to save up being in college and all...its harder to get money for parts and this tune up
