shop u go to get ur brake replaced (SAC AREA)
Old Apr 8, 2009 | 05:44 PM
Kris79's Avatar
battle froggy
at my house lol
Old Apr 8, 2009 | 05:46 PM
azng45's Avatar
how much are you charging chris to have brake change?
Old Apr 8, 2009 | 08:32 PM
oran9e's Avatar
regarding sanding/resurfacing rotors:
Brake Pad
Installation Procedure
1. Install brake pads properly. Be sure pads are securely positioned in the caliper.
2. Flush system with fresh brake fluid.
3. Check all hydraulic parts for excess wear and tear.
4. Check disc for proper thickness, parallelism, and lateral runout.
5. Check disc for scoring or grooves over .012”depth. If either applies, resurfacing is required.
6. If discs do not need resurfacing, then contamination from the previous brake pads must be removed. Sand discs with 130 grit sandpaper using moderate pressure. Use soap and water to clean discs’ surface after sanding and machining. Discs should be free and clear of oil, grease, and brake fluid.
7. Inspect calipers for freedom of movement. Lubricate where necessary.
Red G Coupe
Tuner & Dyno
Jul 30, 2015 08:32 PM
socalg35x
Jul 28, 2015 10:42 AM
newg37
Jul 26, 2015 09:32 AM
Soumilg
Jul 23, 2015 09:26 AM
bickfordbft
Jul 20, 2015 07:57 PM
