Need Help to Unlock and Jailbreak my iPhone4
Old Dec 9, 2010 | 09:31 PM
bmpnride's Avatar
Is there anyone who can help me unlock and jailbreak my iPhone4? I know there are alot of iPhone users here so I hope someone can lend a hand.
Thanks NorCal..
Old Dec 10, 2010 | 04:36 AM
lsmooth81's Avatar
I have iphone 3GS, not 4. But if you go to jailbreakme.com from your iphone it should work. I had to go to previous iOS 4.0.1 from 4.0.2 then go to jailbreakeme.com. What IOS you have on your iphone4? If you have iOS 4.0 or 4.0.1 then it should work. If you have iOS 4.0.2, you will need to downgrade. I can help you downgrade to a previous iOS if you need to, send me a PM, I had to do it for my phone and my wife.
Old Dec 10, 2010 | 12:17 PM
calcul8's Avatar
I can haz potato?
sabertooth tiger
^^ Couldn't have said it better myself. One more thing to note Troy, you'll want to go to that website using a WiFi data connection, not 3G.
Old Dec 10, 2010 | 01:40 PM
lsmooth81's Avatar
I did forget to mention that, WiFi connection very important. Good luck with the process
Old Dec 11, 2010 | 02:56 AM
AlvinJue's Avatar
you can also you greenpois0n to jailbreak your iphone 4 as well. reason why i like it is because every time you jailbreak to a newer iOS, every app, text messages, settings, etc. is saved still and does not get wiped off your phone. prior to using greenpois0n, the older unlockers such as greensn0w, redsn0w, etc. that i used to jailbreak my iphone 3gs and 3g back then, would do a fresh install and you have to manually install everything 1 by 1. it was a PITA. also, the backup process on itunes only backs up and saves your contacts and bookmarks. hope that helps!
tal1412
Nov 28, 2022 09:25 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
xluke
Jul 30, 2016 01:48 PM
douglas555
Sep 10, 2015 04:48 PM
JMSABO
Aug 4, 2015 11:58 AM
