CCFL Rear License Plate
Old Jan 13, 2011 | 07:47 PM
unfadable's Avatar
I was wondering whether anyone has or knows someone that has done this install. I'm not the most handy person when it comes to working on my car , so if there's anyone that can do this please let me know! I guess I can always throw in some LED's if worse comes to worse.
Old Jan 13, 2011 | 07:56 PM
Project's Avatar
Are you talking about a neon plate around the edge?
They are highly illegal and just bring attention to you i dont see why you would put one on.
Old Jan 13, 2011 | 07:57 PM
TORETTO's Avatar
Just do LED bulbs. Don't put a neon light around your plate. It is illegal, and you will definitely get pulled over, especially in California. Not to mention, it will look stupid.
Old Jan 14, 2011 | 01:48 AM
unfadable's Avatar
No Im talking about replacing the standard crappy yellow license plate bulbs that are above the license plate.
This is the thread I'm referring to https://g35driver.com/forums/lightin...corners-2.html
Old Jan 14, 2011 | 01:52 AM
G35SedanGrn's Avatar
lmao thread fail
OP just get LED's and stick em up thr
VLEDS.COM
You're Welcome.
Old Jan 25, 2011 | 09:11 PM
G35xChicago's Avatar
LEDs look like ****, why would u want 2 spotty lights that look ricey and blue?
I did the cold cathode mod and it looks absolutely sick. Like the Lexus plates. Not flashy at all
Basically get a cathode from ebay, 10-12" i beleive. the ones used to light up computer gaming systems. remove metal bracket and stock lights, drill holes in bracket (tough part). Mount light (be careful not to break the cathode, its delicate) using some epoxy glue. Screw bracket back in. run the electrical and tape of exposed wiring. Done.
Mine last over 2 years, it actually just went out yesterday so i will have to do this all over again!
Old Jan 25, 2011 | 09:15 PM
TORETTO's Avatar
^ What the ****?
The Lexus plates use "2 spotty lights". They don't use CCFL bars lmao. You are using computer lightning on your car VS LED bulbs made to fit the car. Not to mention yours is about a foot long. What is rice?
I didn't use blue bulbs on my G35, I used white, and I'm planning on using white bulbs on my evo. Majority of folks use LED's.
"Not flashy at all." - How is a 12" CCFL lamp not flashier than two LED bulbs?
Old Jan 25, 2011 | 09:59 PM
Wow..really??
First off, the Lex dont use cheapo LEDs you find online. 2nd, cold cathode lighting has a lot of applications, computer lighting just being one of them. Yes its a foot long, but its well hidden beneath the bumper assy and you cant actually see it unless you crawl under it and look up.
It provides an even stream of light, which the majority of LEDs that i see on cars, do not. If you found some nice white LEDs, more power to you. The majority i see on the street typically have a bluish hue to them, thats all. But yes, most folks do use led and it takes a lot less time and effort.
Old Jan 25, 2011 | 10:04 PM
TORETTO's Avatar
The 5/6 bulb LED which lights up the area around it, rather than straight forward, is what I used. This resulted in even light distribution over the rear license plate. You couldn't tell if I had 1, 2, or 10 bulbs under there because it was so even.
Now if the OP wants to put a CCFL lamp, then he's free to do so.
But your initial comment on saying LED lights look like ****, as well as ricey and blue is incorrect. That mostly applies for stupid ricers who also rock the bright purple HID kits.
Old Jan 25, 2011 | 10:07 PM
thescreensavers's Avatar
Mr.202?
I have LED's in my License plate bulbs, it gives nice even white light coverage. Putting a CCFL bulb is dumb
Old Apr 7, 2011 | 04:00 PM
sunnyice's Avatar
i dont mean to thread jack but when replaced my license plate light, the bracket where the light clips on to is badly rusted and i was barely able to put it back in cause the bracket was bending. is this normal for the g coupes?
Old Apr 7, 2011 | 04:44 PM
TORETTO's Avatar
Umm, I don't think so.
Each time I took out or swapped my license plate bulbs the bracket was fine. Not rusty at all. It should clip on securely each time.
You can try looking for another one. Or find a destroyed G35 on craigslist that is parting out and you can request that bulb cover.
Old Apr 7, 2011 | 04:48 PM
sunnyice's Avatar
my bulb covers are fine but the bracket were they clip on to is badly rusted as in bad to the point where its bending easily. thats why i kinda struggled putting them back in. i live in ontario which is the rust capital of the world! lol. do you know where i can get a new one? what are they called?
Old Apr 7, 2011 | 04:57 PM
TORETTO's Avatar
I'm not sure what they're called. But you can try calling an Infiniti dealership and describe it to them.
If it's not the actual bracket that you remove, but rather the clip that it sits on, then I'm thinking it might be part of the bumper. If that's the case, I don't know what the cost will be. If you don't mind jury-rigging it for a bit, you can use double sided tape. That stuff holds up well.
Old Apr 7, 2011 | 04:59 PM
sunnyice's Avatar
ok thanks!
boostelevator
Sep 29, 2015 03:23 PM
Nick_M
Aug 3, 2015 11:08 PM
crazy_g35s
Jul 20, 2015 02:30 PM
