Oh, great...
You don't need to remove the bumper or headlight to change that (or any) bulb out. You can access the bulbs from the fender well cover, behind the headlight. Just pitch the tire all the way in to give you the most clearance. Remove the push pins and peel the cover back toward you
The bulb you are looking for is a 7443 (dual filament).
Is this bulb available at the autostore?
When I replaced my headlamp last december I took the bumper off but ended up going through the fender. So much work for nothing. This time I'll just go through the fender. Thanks.
Are there dual function LED bulbs? One that is a DRL and blinker in one?
I went to an auto store. They had the regular bulbs and LED that blink but they weren't sure if it also acts a a DRL.
^Just to clarify... I wouldn't actually buy LED ones from an auto-parts place. There are much better LED bulbs to be found online... I was just saying they probably had them.
ATSGARAGE
Northern California
13
Sep 19, 2010 12:16 AM
