HELP NEEDED! paint headlight housing $$
Old Mar 27, 2013 | 07:27 PM
2007BlueSlate's Avatar
In the South Bay also. West San Jose/Cambell area.
Old Mar 28, 2013 | 01:37 PM
StricklyG_'s Avatar
Originally Posted by G35Papa
Bacon....add some bacon to the headlights and all will turn out delicious!
You have my number Chris? Hit me up but I doubt you'll need to.
If you have a sedan, now is the perfect time to clear the turn signal lenses
Hey Guys.. I'm New To G35driver, And I'm Going To Be Doing This To My G (Sedan) On The Weekend.. So G35Papa Can You Please Help Me Out And Letting Me Know How To Clear Out The Turning Signal Lenses.. I'm Interested In Doing This As Well..
Old Mar 28, 2013 | 06:07 PM
G35Papa's Avatar
Sure. I snapped some pics. Give me a day or two and I'll post up the pics and link to the lenses I used.
Old Mar 29, 2013 | 12:32 AM
StricklyG_'s Avatar
Thanks In Advance Man.. Appreciate it..
Old Mar 29, 2013 | 01:00 AM
achursin's Avatar
I'd use a heat gun instead. Doesn't leave the yellow tint on the headlight. Can rent it in a nearby shop if available. But that's just my preference. First baked a pair on my acura to fit halos or what not and though the housing and the lighting came out perfect the light itself had a yellowish tint after rebaking to clamp it back up. Followed as instructed so not sure if it was my oven...
Old Mar 29, 2013 | 01:17 AM
TORETTO's Avatar
i have a heat gun if that's the case. i'll try that instead.
Old Mar 29, 2013 | 02:26 AM
achursin's Avatar
Let me know how it turns out fellas hope my input helped. Also just to add be careful not to break the clips. I used a regular flat head to pull the housing apart from the lenses. As far as putting it back together just same concept make sure to warm that stuff up and smoosh it together real tight (another project on my coupe wasn't sealed properly and suffered condensation. So I'd say buy extra just in case.
Old Mar 29, 2013 | 01:54 PM
G35Papa's Avatar
All the sets I've done in the past not one has ever turned yellow from baking them. Knock on wood Heat gun works too just dont leave it in ones spot for too long
I was going to add the details to the headlight painting DIY but there is no more room available in the original post
https://g35driver.com/forums/lightin...ml#post3920746
Note that the 05/06 sedans you can use any 2.5" projector lense. You can pick up a set of "Value" (see options on the site) clear lenses from the following link for $20.
http://www.theretrofitsource.com/pro...roducts_id=134
03/04 sedans need a smaller lense. Around 2". There use to be an ebay seller but I can't find them anymore I'll keep looking though
I used a dremel spiral cutting bit to remove most of the orange turn signal lense. I then used a sanding wheel bit to sand down the rest of the lense. Then sanded the circle by hand to smooth out the raised edge more (400 grit works well)
After I painted everything up and put the lense in place, I used a thin bead of clear silicone to glue the lense in place. Do this from inside the turn signal house all along the outside edge. I suggest letting the silicone dry overnight.
Hope it helps, PM if if you have any questions
Old Mar 29, 2013 | 01:58 PM
achursin's Avatar
Darn it!!! Must have been the oven.....
Great DIY BTW.
Old Mar 29, 2013 | 01:59 PM
G35Papa's Avatar
Thank you
Yeah, if you set it to Broil, that's a big no no. One person did it years ago and melted his lenses
Old Mar 29, 2013 | 02:37 PM
achursin's Avatar
Its not like it was terrible, i dont have any high-quality pics of the acura (apologies) but it bugged me for the longest though the halos (super cool back in the day) made it up.
Old Mar 29, 2013 | 05:05 PM
TORETTO's Avatar
Thank you
I hear you have to buy a kitchen oven that is approved for headlight baking.
Headlights. It's what's for dinner.
Old Mar 29, 2013 | 05:36 PM
G35Papa's Avatar
^High in protein, low in fat!
Something like that would bug me too achursin
Old Mar 30, 2013 | 03:19 AM
rdavis's Avatar
I would like mine painted as well I'm in 90621 anyone around me?
Old Mar 30, 2013 | 03:23 AM
  #30
rdavis's Avatar
I would like to also switch out the orange corners and have one projector setup
