Help with suspension noise
Old Mar 26, 2014 | 06:14 PM
rwcblkcoupe's Avatar
Hey nor cal!
Ok so in going to be putting on a used set of coil overs on soon. I am having some major squeaking coming from the front suspension! Seriously it sounds like a 50's pick up! So I recently put on kinetics adjustable upper control arms and have no doubt they are part of it. I will re grease them at time of install.
Questions: first when I do put on the coils, is there any bushings or other parts I should replace before the install? I have replaced the lower control arms and the bushings that always go bad( I forget what they are called) with white line. I would like to do everything at once while I have the car torn apart.
Second: any ideas on what might cause the squeaking? Other than the upper control arms?
Thanks for any help you can give
Old Mar 26, 2014 | 10:36 PM
ScraggleRock's Avatar
Any of those polyurethane bushings can squeek if they aren't greased well enough, but its most likely the kinetix arms bushings. They have a zirk fitting tho so just load em up with lithium grease. The control arm and compression rod bushings tho, did you use silicone grease? Energy supplies it with their bushings. Real nasty nasty sticky thick stuff. That's what you need to use tho.
Old Mar 27, 2014 | 01:10 AM
WTF??'s Avatar
ughhh.... i gotta replace my compression rod bushings too...
been in touch with bythebay, but Ive been laggin
Old Mar 27, 2014 | 07:14 AM
Don't just replace the bushings tho. The rods have an irreplaceable ball joint too. You need the whole rod, but you want poly bushings. It's the only way to go on our cars. I have a brand new set with new ball joint and poly bushings. I'll grese em up and send em to you for $250+shipping.
Old Sep 6, 2014 | 02:06 AM
I'm sure you got this figured out by now
So if you have not figured it out yet. The kinetics don't have Grease fittings you need to pull back the cover and pack the crap out of them with grease. I had this same problem...
Originally Posted by rwcblkcoupe
Hey nor cal!
Old Sep 6, 2014 | 03:14 AM
Huh? My kinetix have zerk fittings.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
