Help!!!!
Help!!!!
Anyone have experiece installing a Stillen airbox??? I cannot get the damn screw on the bottom to go in!!! I scraped up my arm for an hour and still can't get it on.
If anyone can help, i'll buy you lunch!
You don't really need that bottom screw. I put that screw in at first, then looked at how close the a/c line is to the bottom of the intake, so I took out the screw and put some foam in between the frame and intake, and left the screw off. It will stay in place with the remaining screw on the top of the intake. I've had no problems without the bottom screw. Good luck
