NorthWest Serving AK, ID, OR, WA
Need help installing springs....Beaverton
Old Sep 6, 2006 | 04:20 PM
townsley's Avatar
The thing is - after you remove the wheel, and disconnect all the bolts holding the strut in per the DIY on g-owners, there is no tension on the spring - the whole spring/strut assembly is just loose in the well.. Using the compressors is just so you can collapse the spring/strut so it's short enough to fit under the control arm. By removing the arm, on which there's no tension but gravity, you don't need the spring compressors.
Please don't take my word for it - I'm *following* DIYs, not writing them. I've done it twice and bypassing the spring compressors takes about 2 hours, and a lot of elbow grease, out of the equation. The front strut/spring is an integrated unit that is pulled and replaced as a single assembly.
Old Sep 6, 2006 | 04:41 PM
townsley's Avatar
I see the confusion now - thanks for bring this up Jeff92se...
My experience is NOT in replacing the front spring. My experience is limited to replacing the front spring/strut assembly as a single integrated unit. So, in my experience compressors were not needed. Anyone removing the spring from the front strut will definitely need compressors.
Old Sep 7, 2006 | 01:24 AM
redlude97's Avatar
Dangit, I thought someone had a clever way of compressing the springs without a spring compressor. I've hear of people using c-clamps to compress the springs, but I would rather not do it the ghetto way and hurt myself or someone else. Anyone know where I can rent/borrow a spring compressor?
Old Sep 7, 2006 | 02:04 AM
yamanb's Avatar
shucks or autozone. Costs like $6 to rent.
Old Sep 7, 2006 | 02:11 AM
Jeff92se's Avatar
Red Card Crew
Fortunately, I'll be replacing the entire strut/spring at one time also.
For Redlude97, I'd just rent. It's cheaper than fingers and eyeballs!
Old Sep 9, 2006 | 04:12 PM
townsley's Avatar
Redlude - I've got some compressors you're welcome to use if you want. They're just sitting in my garage collecting dust. PM me if you're interested.
Old Sep 10, 2006 | 11:36 PM
redlude97's Avatar
Townsley,
Thanks for the offer, if I end up installing them myself, I'll get in touch with you. I've only got a week left before I head to school, and i still need to finish building my box, getting my spoiler painted, and blacking out my headlights so I don't know if i'm going to have time to do the install myself
Old Sep 11, 2006 | 03:58 PM
jiggalam's Avatar
How are you blacking out your headlights? I am most interested to know.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
