NorthWest Serving AK, ID, OR, WA
Drewer?? How's it??
Old Aug 20, 2007 | 03:32 PM
MixturePinoy's Avatar
Drewer?? How's it??
How's the ride coming along. hit us up with updates!
Old Aug 20, 2007 | 06:49 PM
Drewer's Avatar
LOL I was busy flying a CJ-525 last week. . .so nothing new or exciting to report. . .
Well, actually I guess I'll be ordering my Innovate LC1 Duo, the UTEC, Walbro, and DW 650cc injectors in the next week orzo. Install will *probably* happen mid September.
Old Aug 20, 2007 | 10:14 PM
Triple8Sol's Avatar
You went with 650cc injectors? Are you worried about a rough idle? I'm planning to go 2.87 & RC 550's later this year.
Old Aug 26, 2007 | 08:31 PM
Jining's Avatar
650's are fine
Idle is not rough at all, I have the same setup you are getting basically.
Old Aug 26, 2007 | 09:13 PM
Triple8Sol's Avatar
Originally Posted by Jining
650's are fine
Are you sure you know what you're taking about? Running a UTEC alone, like I am (and Drewer will be) you can only adjust fuel in boost. You have no control over vacuum, since it is just a piggyback. Speaking to mechanic friends, 650's are highly likely to cause a rough idle. With certain standalone EMU's, you have the ability to make adjustments outside of boost, so you can smooth out your idle.
Old Aug 26, 2007 | 09:17 PM
Jining's Avatar
My car is running utec as well, and I just drove it here to work.. yea im quite sure the idle is not rough. 650 is not that big.
It actually idles on the lean side ~15-15.5
Old Aug 26, 2007 | 09:18 PM
Jining's Avatar
if either of you want to come by and check it out, just to make sure its not too rough for your tastes, but IMO its same as stock.
Old Aug 28, 2007 | 03:30 PM
Drewer's Avatar
I'd like to check it out. . .
And doesn't the UTEC do injector scaling? The 650cc's with the vortech are only for a larger "foot print" of gas so as not to need a return system.
-andrew
Old Aug 28, 2007 | 04:16 PM
Triple8Sol's Avatar
-andrew
I'd like to check out the whole APS TT as well. Haven't seen one in person yet.
As far as the scaling, you're the expert Andrew So does it?
Old Aug 28, 2007 | 05:05 PM
Drewer's Avatar
Yes. . .yes it does according to the manual.
Old Aug 28, 2007 | 05:07 PM
Jeff92se's Avatar
Red Card Crew
You gonna self tune Drew?
Old Aug 28, 2007 | 06:59 PM
Drewer's Avatar
Yes, that's the plan.
Old Aug 28, 2007 | 07:41 PM
Triple8Sol's Avatar
Are you going to download a UI, or just use HT like I did?
Old Aug 28, 2007 | 07:58 PM
Drewer's Avatar
I'll probably use HT like you. . .but I plan on getting a little "beater" laptop to keep with the car permanently.
Drewer
Interior
18
Mar 29, 2011 01:54 AM
GoSooners
Archived Sales
11
Aug 23, 2006 01:15 PM
GoSooners
Archived Sales
May 31, 2006 02:27 AM
