FS[West]: Heavily modified NA 06 Z, Base MT, Blue
Old Apr 12, 2013 | 06:47 PM
e30cabrio's Avatar
I am sad to sell my baby. I have almost 3 years of blood sweat and tears in this car but need more space.
The car is a base but has cruise, the radio controls are there and I have the box which will let them run my Kenwood DNX9080 DVD NAV which has the latest map but I never installed it.
The stock cluster does not have the LED to show cruise is on but I will include one that does. I could not find anyone to set the correct mileage to the other cluster.
Dealer trade on a 91xxx mile stock 06 Z is 14k this car has over 20k in mods including a 5k mile motor and clutch. I think 20k for a car with 33k+ in value is more than fair. Come drive it & you will be hooked.
VIN: JN1AZ34D26M309210
The car has too much to list. I have over 20k in receipts of mods including a full motor build using 100% new discontinued Brian Crower 88mm crank, BC Sportsman rods, Brian Crower spec special order JE pistons and rings, ARP head & block studs billet aluminum bottom end heavy duty girdle, Bosch waterpump, Cometec special order heavy duty head gaskets and on & on. The car had Akebono G37S big aluminum 4 pot front/ 2 rear calipers 14" DBA 2 piece lightweight front rotors & 13.75" Centric rears. New parking brake shoes and EBC Redstuff pads front & rear just installed. The motor has 6k miles as does the Act HD clutch, lightweight flywheel and pressure plate. The rear end has a Titan 4.308 final drive and quaife LSD.
The car has a RevUp tune and made over 300 whp & torque. It runs and dives perfectly. The brakes are amazing.
The suspension is completely aftermarket. All arms, are SPC or SPL, it has AMR adjustable coil overs that can go from softer than stock to filling jarringly firm. Hotchkiss sways, powergrid endlinks and 8/32nd Potenza RE770s 275 35 18 front & rear on +20/+12 Rotas (only knockoffs on the car).
I am forgetting as much as I posted. This is my signature on MY350Z.com
4.0 stroker with all bolt ons & UPREV Quaife with 4.083s, AMR 13k/11k coilovers, Hotchkiss sways, Powergrid end links & SPL front and rear camber arms Kenwood DNX9980 DVD NAV, Alpine MRP-F450 4 channel running Image Dynamics CX64s, JL M1700 running JL Audio 10W3V3 in Wicked CAS magic box.
This is the thread from purchase to end.
http://my350z.com/forum/na-builds/51...-na-build.html
This is the year long saga tat was the motor build.
Differential fully rebuilt, new final drive installed, quaife verified good.
quaife was bought direct, that price is pounds.
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
TurTLe*
Sep 29, 2015 01:43 PM
