Considering a de-mod
Ohio G Club moderator
OP, If they didnt e-check where i live i would consider those test pipes =/
IrockAG35, injen produces some nice sound but i hear people bitching about the cabin drone it also creates. I haven't heard the drone first hand so i cant say how bad it is. Did you install it yet? Hows it sound in the cabin?
Someone was selling their injen SES here in the marketplace, he swapped it out for a HKS. I was considering the injen at the time and i asked if it was because of the cabin drone he was getting rid of it, this is what he said regarding it. He was using stock cats. Kinda turned me away from the injen.
To be honest, the drone is bad with non-resonated test pipes between a little under 2k to the upper 2ks rpm, but over time i got used to to them. resonated test pipes or cats i'd imagine make things a lot quieter in the cabin. another advantage of the injen over the hks is its weight, the hks y pipe weighs about as much as the front and mid injen pipes. any weight you can get rid of in the g is a good thing.
Mike all I know is I took J to pick his car up from Slo MO after the retune and he was beside me and punched it and I got a stiffy from the exhaust. It sounds diffrent with FI attached to it.
my exhaust even sounds different than dal's. even though we had the same set up. It has a complete different sound. I subie owner called it beautiful the other night after I walked on his sti...
So as it stands now the car is more than likely going to get de-modded in the Spring when I pull it out of storage and attempt to sell it stock.
I currently have someone interested in it from Florida but for some reason I get the feeling he will flake out
ur correct...just sounds to...quiet to me, sounds alittle louder than stock imo..but looks sick. i think once hes built it will louden up alot!
