Power window not working
Old Jan 3, 2010 | 03:01 PM
plumber78's Avatar
It worked out great! It was really easy too. Just make sure that if you clean out the motor don't clean down deep where the shaft is. I started to and noticed that there was grease down there. There are a couple of contacts that are probably the critical points to be cleaned. If you are not comfortable doing this Brian, I can help you on our next install meet. It really is easy though. Thanks Joe!
Old Jan 3, 2010 | 03:50 PM
O HELLA OEM's Avatar
good to hear Grant. i guess im having the same problem as you. but sometimes my window doesnt go down or up. very odd.
Old Jan 3, 2010 | 04:12 PM
BuckeyeG's Avatar
You can always try to spray WD-40 down in your switch. I had a car a long time ago and the drivers window wouldnt work and I tryed that and low and behold that worked. If its the motor though of course that wont.
Old Jan 3, 2010 | 04:14 PM
plumber78's Avatar
I really do think that it is your switches or the wiring harness to those switches. Do you ever have a problem with being able to switch your lock as well? It took a couple of tries putting everything back together to get the switches to work for me. Luckily you don't even have to take the door panel off to get to that. They just pop up off the door. If you don't hear them clicking when you move them up or down then you know that is what your problem is.
plumber78's Avatar
You beat me to the punch lol.
Old Jan 4, 2010 | 07:34 AM
Jomanchu's Avatar
Ohio G Club Member
No problem man..Im glad it worked out for ya
Old Jan 4, 2010 | 08:24 AM
g-adabout's Avatar
Good to hear it worked out!
Old Jan 4, 2010 | 10:59 AM
cdubel01's Avatar
CLUB MODERATOR
I have had to do this to my window motor a couple times, apparently carbon or something builds up in there, but once you do it, you should be good. Yea, did you enjoy removing all those nuts? Pain in the butt, but saves money...I need to get my door locks fixed if anyone knows how to do that. The door lock actuators are like $300 for both i think and then they have to be installed...I currently just manually lock 'em...
Old Jan 4, 2010 | 11:30 AM
plumber78's Avatar
Sounds like we need an install meet!!!
Old Jan 4, 2010 | 12:52 PM
BuckeyeG's Avatar
Spray some WD down in those switches Chris.
Old Jan 4, 2010 | 01:03 PM
My drivers side door lock went out a few months ago,
so I purchased a new acuator from rick@riverside for
like 160-170 I believe then I had my Infiniti dealership install
it and it cost me $180 in labor!!!!
Old Jan 4, 2010 | 02:51 PM
cdubel01's Avatar
CLUB MODERATOR
yea, not really feelin the $300/door cost with labor and parts....
Old Apr 22, 2019 | 02:51 AM
Ryan Schmidt's Avatar
G35 coupe
Relay
Actually Brian the more I think about it, your problem may be the switch relay. I noticed mine was acting a little funny when I had it pulled out...almost like there was a bad connection. If it is that, that is super easy to change out. I am not sure how much it costs though. Don't quote me on that...I am a plumber, not an mechanic lol.
Where is this relay?any info greatly appreciated
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
