http://sellout.woot.com/?ts=12688199...4af27cf9278004
Doesn't scuff your car if it hits (if you're good you won't even let it hit lol)
Uses a water powered piston engine to rewind the hose!
"Marine hose means that the hose is aproved for drinking water (used to fill drinking water holding tanks on boats and rv's). All marine aproved hoses are white with blue line."
"By turning the NO-CRANK's lever after watering, the water pressure is diverted from the hose to the Hydro-Pro™ water piston engine. The water pressure moves the pistons and a simple gearing system transfers the motion to the drum which rewinds the hose. While rewinding the hose the excess water exits the water piston engine, via the exit hose, and is used to water the area near the hose reel.
The Hydro-Pro™ engine has been driving ReelSmart and NO-CRANK hose reels for more than 5 years with more than 1.5 million units sold and installed.
The Hydro-Pro™ system is protected by numerous patents and can only be found in Hydro-Industries' products."
I picked one up, $30 for a cart and a good quality hose
