Throttle Body Issue Please Help!!
Old Nov 15, 2010 | 08:15 PM
SxExCx's Avatar
You will need to do the throttle reset. You can get the procedure on the Technosqure website.
Old Nov 15, 2010 | 09:36 PM
Rambo's Avatar
Originally Posted by IrockAG35
if u need the ecu reset write up,i have it..lmk
Originally Posted by Project
When you say you cleaned the throttle body how did you go about doing it?
Its a common issue cleaning that these get messed up.
I used throttle body cleaner from autozone. we will see. Either way i am having an issue with the throttle body. If it is still messed up I will just buy one.
Old Nov 17, 2010 | 06:55 PM
Rambo's Avatar
Ok. so everything is clean. It still does the same thing just a less violent startup
However, I found something interesting. My battery died after attempting to start it several times. Which leads me to believe that due to a low voltage battery (that was enough to get it started) was not strong enough to supplement the time before the car ran on the alternator. We did just have a cold swing so this may be the root cause. I am going to get a new battery tomorrow.
Let me know your guys thoughts or if you have any other ideas.
Old Nov 17, 2010 | 08:47 PM
BuckeyeG's Avatar
Sounds like it could be a very good source of your problem. Does it run fine after its on for a few and gives time for the alternator to kick in?
Old Nov 18, 2010 | 03:37 PM
g-adabout's Avatar
its always something simplier that what you believe!
Old Nov 20, 2010 | 01:48 PM
Rambo's Avatar
Well that was not it...it still just turns on and does not go to idle.
Old Nov 28, 2010 | 09:30 PM
Rambo's Avatar
Well took it somewhere and they found oil comming from the head...not good. So I am going to pull the motor and give it to corey at slomo for a full build...anyone want to donate a turbo kit???
Old Nov 29, 2010 | 03:09 PM
g-adabout's Avatar
hahahha, I want to sell mine and get a twin set up...but not right now.
Old Nov 30, 2010 | 06:01 PM
Rambo's Avatar
keyword donate....it will be tax deductible!!
Old Nov 30, 2010 | 06:02 PM
g-adabout's Avatar
killer pleaaaaase!
Old Nov 30, 2010 | 06:09 PM
Rambo's Avatar
I will trade you 2 ohioG longsleve shirts for your turbo kit.
Hasanbaloch
Feb 29, 2024 08:45 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
03sedang35
Aug 29, 2015 07:56 PM
