General Questions
Old Apr 13, 2011 | 03:32 PM
  #46
MRRJP3's Avatar
I have less than a inch clearance now tire to fender. Nate with the 500hp Z told me after great inner debate I would be scraping tire even with my fenders rolled, trust me I am as dissapointed as anybody
Old Apr 13, 2011 | 03:41 PM
  #47
X-FactorWR87's Avatar
CLUB MODERATOR
Originally Posted by MRRJP3
I got Tein Lowering Springs, rear shocks, rear camber arms for sale, not lowering mine it's been declared too low with my 19's on, by my Z guru, so I got parts to sale!!!!!!!
pm me some prices
Old Apr 13, 2011 | 03:50 PM
  #48
bash27jp00's Avatar
Ohio G Club Member
you must be running some thick tires
Old Apr 13, 2011 | 07:33 PM
  #49
MRRJP3's Avatar
275/35/19 rear 245/35/19 fronts, trust me I wanted it as bad as anyone but when Nate warnes against it I listen. Can't have bad handling on the Tail of the Dragon
Old Apr 13, 2011 | 09:43 PM
  #50
g-adabout's Avatar
Your Z looks good now...I disagree with Nate on the fender rolling and rubbing, but cool...
Old Apr 16, 2011 | 09:14 AM
  #51
btc6640's Avatar
I got the same rotors that came on my car from the dealer. When I bought they had rust and when I polish it off it comes right back. So I want to replace them with a good set, any suggestions?
Old Apr 16, 2011 | 09:38 AM
  #52
Dal35's Avatar
TuningWerks Competition
Stillen Slotted Rotors.
Old Apr 16, 2011 | 09:41 AM
  #53
Dal35's Avatar
I'd like to see it. 275's shouldn't be a problem. I know ppl roll their fenders at 285's.
Old Apr 16, 2011 | 09:47 AM
  #54
carsontl's Avatar
they're rotors... if they sit they'll rust... then you drive and apply the brakes... rust goes away...
Old Apr 16, 2011 | 11:15 AM
  #55
btc6640's Avatar
Yeah I agree but where the majority of the rust is that I've polished off in the past is where my rim marries up to the rotor where the break pads don't touch. You can see it from yards away. Thanks dal ill take a look at them!
Old Apr 16, 2011 | 01:12 PM
  #56
MRRJP3's Avatar
Chicago Automotive on Ebay drilled and slotted, ballin on a budget !!!!!!
Old Apr 16, 2011 | 01:19 PM
  #57
MRRJP3's Avatar
Let me know when u got time I'll swing it by so you can tell me what you think. Nate was saying it will bareley fit an if there a dip or bump I'll bottom out quite a bit, his biggest concern was the handling issue. I could drop it for Show!!!! But my Go!!! Is going to be compromised.
Old Apr 16, 2011 | 09:31 PM
  #58
Z_ology's Avatar
I don't think you will have rubbing issues if you roll the fenders. I was just sayin that rolling could be a little hit or miss to do without cracking the paint Nate
Old Apr 17, 2011 | 09:01 AM
  #59
Rambo's Avatar
springs are probably on the plate this year, gonna keep these rims for another year atleast if not longer (may get them refinished)
Can't decide between s-techs and eibach pro kit... hmm.
I have done a lot of research on springs. I finally opted for a set of RSR springs as they are linear and the spring rates are slightly stiffer all around. This will allow me to corner better with more consistent control. The teins and eibachs were my second choice which are very comprisable to oem and still give good ride quality.
I also agree with J. camber kits all around are the way to go especially if you care about saving your wallet from tire ware. I went with toxico dspecs as they are fully adjustable shocks. The HPs are not but are a very good alternative.
info is here: http://my350z.com/forum/brakes-and-s...n-101-a-2.html
I am just waiting on finding a good price for a set of spc or eibach rear camber kits. and then I will be dropping my car.
I was also considering plast-i-dip painting my oems there have been a few guys on here that have done it and it looks pretty good. Tom let me know what you think I need a second opinion. Also, I do not know if I can part with my OEM 19s as they are some of the lightest 19" rims you can get on the market.
Old Apr 17, 2011 | 09:50 AM
  #60
carsontl's Avatar
if you plastidip I might do it too lol, my rims currently look terrible (previous owner etched the **** out of them)
