Rambo's LS1 Build
Old Nov 20, 2011 | 07:26 PM
  #46
Rambo's Avatar
Time for an update.
Total list of things Huck's Machine Shop did for me:
1. Clean Block, Valves, Valve Covers, and Heads
2. Inspect and Deck heads flat
3. Magnaflux Crank, Grind, and polish
4. Inspect block
5. Bore, hone, and match block to pistons
6. Recondition stock rods with ARP bolts
7. Assemble rods and pistons with pressed in wrist pins (THEY DID IT FOR FREE!!)
8. Replace cam bearings
9. Full balance of rotating assembly
10. Ground flywheel (THEY DID IT FOR FREE!!)
11. Furnished Main and Rod bearings
Final machine shop cost with ARP rod bolt, main bearings, and rod bearings: $1335.41
Time for pics:
Freshly Cleaned, Bored, Honed Block:
Is that Chevy Red-Orange I see:
Why yes, yes it is:
Fresh Parts!!!
Piston Assemblies:
New Piston Assembly with ARP Rod bolts and MAHLE Pistons:
Freshly Ground and Balanced Crank:
Cleaned and decked heads:
I also got the fly wheel, rod, and main bearings. Time for short block assembly to begin....
Old Nov 21, 2011 | 09:44 AM
  #47
X-FactorWR87's Avatar
CLUB MODERATOR
beautiful!!
Old Nov 21, 2011 | 10:40 AM
  #48
cdubel01's Avatar
CLUB MODERATOR
Did Christmas come early???
Old Nov 21, 2011 | 12:06 PM
  #49
Rambo's Avatar
Yeah santa's sleigh has a V8!!!
Old Nov 21, 2011 | 12:56 PM
  #50
Awilli's Avatar
Rambo
Be sure and clean out every bolt hole Especally the Head bolt holes on that block before torqing to it! LSx blocks have blind = closed on one end- bolt holes, Cleaning and Machiening leave all kinds of sh*t in them, if you torque to liquid or dirt in one of these holes you will crack that block. I'm over on LS1 tech Too since I've had my formally LS1 now LS6 Z28 longer than My G35. ARP has a special long thread cleaner just for the head holes summit sells it or you might be able to get a used one off LS1Tech.
Old Nov 22, 2011 | 01:07 AM
  #51
Rambo's Avatar
Originally Posted by Awilli
Rambo
Yup, I will be doing a through look thru and clean over the next week. Then it is off to checking clearances and fitment.
Old Nov 22, 2011 | 06:32 PM
  #52
g-adabout's Avatar
Awesome bro! Cant wait to see it. Thank you for all the pics and updates!
Old Dec 3, 2011 | 06:02 PM
  #53
Rambo's Avatar
New micrometers for verifying clearances. New bore gauge is on the way!!
Old Dec 5, 2011 | 03:46 PM
  #54
g-adabout's Avatar
<<<<NOTICE>>>>
All future Install meets will be located at Rambo's Garage!
hahahaaaaaaa
Old Dec 5, 2011 | 03:53 PM
  #55
g35man04's Avatar
CLUB MODERATOR
Nice updates man!! I am picking up my whole LS1 Block in the next few days or at the end of the week!!! just need to get the Accessory Drive kit, cam, start picking up the sikky kit from our local shop here!! turbo and motor is being pulled out of my car by the end of the week!
here is the one I got!! If you want me to delete the photo just say so!
Old Dec 5, 2011 | 10:25 PM
  #56
Rambo's Avatar
Nah! The more LSs the better. What was it pulled out of? Mine is out of an 01 SS camaro. Ended up being an LS6 block w/241 heads.
Old Dec 7, 2011 | 11:47 PM
  #57
Rambo's Avatar
JEGS SENT ME THE BORE GAUGE WITH MISSING PARTS!!!! WTF!!
Old Dec 8, 2011 | 10:48 AM
  #58
cdubel01's Avatar
CLUB MODERATOR
well, that's some BS....
Old Dec 8, 2011 | 11:10 AM
  #59
redpearl99's Avatar
what did Jegs say when you called them
Old Dec 8, 2011 | 03:12 PM
  #60
g-adabout's Avatar
That sucks. I hope they make it right!
