Rambo's LS1 Build
Old Jan 14, 2012 | 09:18 AM
  #91
Rambo's Avatar
I plan on using chase bays and a GM ECU w/tune for all my wiring. I want to retain AC and use as much LS2 stuff as I can. And yeah, definately would be nice to have all the money right now. Instead of being stuck buying a few parts here and a few parts there. I am shooting for 420-450hp at the rear wheel NA on stock 243 heads, 6800-7200 rpm redline.
Old Jan 22, 2012 | 04:36 PM
  #92
Rambo's Avatar
Should have an update next weekend. I am having a hard time getting the rod bolts off. Need to make up a good vice setup. Also, I will be making my piston ring squaring tool this week. Last tool I need.
Old Jan 22, 2012 | 05:06 PM
  #93
sh0rtys463's Avatar
Damn, I need to do this! Wonder how I could pull this off in CA?
Awesome Build!
Old Jan 22, 2012 | 05:14 PM
  #94
ryamartin's Avatar
Awesome Build!
as long as the motor being swapped is from the same model year or newer than the chassis and retains "stock emissions devices" and OBD2 it will pass cali smog.
Old Jan 22, 2012 | 05:44 PM
  #95
sh0rtys463's Avatar
Thanks for that..I wasn't aware of this. Looks like I have something to look forward to for the G
Old Jan 22, 2012 | 11:22 PM
  #96
g-adabout's Avatar
Awesome! I love that you are going higher revs...I cant wait to hear your LS reving 7ks!
Old Jan 24, 2012 | 11:51 PM
  #97
Rambo's Avatar
Yeah it is going to sing!!
Old Jan 27, 2012 | 07:06 PM
  #98
Rambo's Avatar
Decided 50 bucks was way too much to spend for a piston ring squaring tool. So i made one. Turned out great, not bad for $FREE.99
Old Jan 27, 2012 | 08:11 PM
  #99
g-adabout's Avatar
ok...fine. You can build my motor too! hahahaaaha Nice work!
Old Jan 27, 2012 | 09:28 PM
  #100
Rambo's Avatar
my pleasure.
Old Jan 29, 2012 | 08:04 PM
  #101
Rambo's Avatar
Checked crankshaft end play. Looks good. I also finally got the piston rod bolts loosed up so I can start assembly of the bearings
Old Jan 29, 2012 | 08:09 PM
  #102
JaE35's Avatar
Moderator
G35 Sedan
sexy
Old Feb 13, 2012 | 09:54 PM
  #103
Rambo's Avatar
Time for an update!!
The rod bearings and connecting rod/piston assembly.
Dropped in the rod bearings.
Bearings are ready for clearance inspection. Seven more to go...
All the Piston/Rod assemblies ready for rings.
My piston ring squaring tool works!!
Piston ring #3 all gapped up and ready to go.
The full piston assembly rings, rods, bearings, and pistons. The whole caboodle ready for assembly.
Piston rings installed.
After a bitch of time figuring out how to get my ring compressor working correctly (wouldnt close all the way) on piston #1 the rest dropped in nicely.
Bottom end all buttoned up!
ARP Rod bolt close up!
All Pistons In!!! Time to find a cam!!!
btw this build is sponsored by budwieser. 5 hrs of working on a motor cannot be had without a few cans of beer.
Old Feb 13, 2012 | 10:07 PM
  #104
JaE35's Avatar
Moderator
G35 Sedan
lol beautiful
Old Feb 14, 2012 | 10:24 AM
  #105
X-FactorWR87's Avatar
CLUB MODERATOR
dang bro! looks good!
