Rambo's LS1 Build
Old Feb 14, 2012 | 01:23 PM
  #106
ryamartin's Avatar
Rambo- with your piston ring squaring tool, do you have access to a cnc machine or lathe?
I have a project that has been floating around in my head but I need someone for machining.
Old Feb 14, 2012 | 08:11 PM
  #107
g-adabout's Avatar
I cant wait until this is finished. I hope its during the summer so I can help lower it in!
Old Feb 14, 2012 | 10:40 PM
  #108
Rambo's Avatar
I just made it on a lathe. Our cnc is down right now at work and have not had time to fix it. What are you wanting to build?
Old Feb 17, 2012 | 10:02 PM
  #109
Rambo's Avatar
Just got an LS2 Intake manifold so I can use my 90mm Throttle body. I am going to port this one, then some day get a FAST set up down the road.
Old Feb 17, 2012 | 10:03 PM
  #110
JaE35's Avatar
Moderator
G35 Sedan
sick, very nice
Old Feb 20, 2012 | 06:08 PM
  #111
Rambo's Avatar
Just purchased an EPS 226 INT./230 EXT. .600 lift custom cam today....2 weeks and counting until I get it. I am hoping for 40+hp over stock with good throttle response.
Old Feb 20, 2012 | 07:51 PM
  #112
g-adabout's Avatar
Saweeet!
Old Feb 21, 2012 | 04:02 PM
  #113
X-FactorWR87's Avatar
CLUB MODERATOR
looks good!!
Old Feb 21, 2012 | 10:04 PM
  #114
Rambo's Avatar
Originally Posted by g-adabout
Saweeet!
Thats what she said.
Old Feb 28, 2012 | 11:07 PM
  #115
Rambo's Avatar
Just ordered a new cam retainer plate, ARP cam bolts, rear main seal, rear gasket, LS2 cam gear, and C5R timing chain. Should be enough to complete the rotating and timing assembly.
Old Mar 15, 2012 | 07:24 PM
  #116
Rambo's Avatar
All my timing components in!! And my E40 ecm!! I am going to install them this weekend.
C5R Timing Chain and Crank Turning Tool (This is a godsend!!)
Custom ground EPS 226/230 .600" lift cam.
Old Mar 16, 2012 | 06:52 AM
  #117
RicoG35x's Avatar
this is going to be a freakin' BEAST!!! NICE!
Old Mar 17, 2012 | 05:02 PM
  #118
Rambo's Avatar
Time for an update. Got the timing stuff all installed!!
The new cam, all lubed up and only one place to go...
It went in so good!!
Rear Seal and Rear Cover are in!!
I was interrupted by the mail man. He had a present for me!! Timing chain damper came in!!
Cam retainer plate is in and I drilled and tapped the block for the new timing chain damper!!
Cam timing mocked up. Dot to dot. Pretty simple.
Timing gear, C5R chain, and timing chain damper installed!!
All done for today. Short block is almost done!! Just need an oil pump and front cover.
Old Mar 18, 2012 | 10:54 AM
  #119
RicoG35x's Avatar
beautiful.. simply beautiful!
Old Mar 18, 2012 | 10:36 PM
  #120
g-adabout's Avatar
Awesome Rambo! I the excitement is building!
