Other Cars Other Cars classifieds
2004 g35 low miles 6spd,brembos,navi,turbo,utec,fully built,etc!!!! Great deal!!!!
Old Mar 27, 2009 | 12:38 AM
Z33=MONEY's Avatar
2004 G35 LOW MILES 6SPD,BREMBOS,NAVI,TURBO,UTEC,FULLY BUILT,ETC!!!! GREAT DEAL!!!!
This car has a salvage title. It was in a light flood only, No frame or other body damage occured. This car had no collision damage. The motor has 3000 miles and 42000 miles on the car. I have all of the receipts for all of the work and parts .the oldest receipt is 1-28-08 so all the parts are like new. I had the car dynoed and tuned. It did 380 RWHP at 9 psi (Potential of a lot more with more boost ).
ENGINE
T4 60-1 Ball Bearing Turbo
3.0" Downpipe (No Cat)
Spearco intercooler
Raptor blow-off valve
Evolution wastegate
Re-flash engine management Walbro in-tank hi-flow fuel pump
Stainless oil feed line
Intercooler fan controller (G35 kits)
Taps for oil return and oil feed fittings
Polished stainless exhaust tubes with v-band connections
Black chrome aluminum intercooler pipes
Silicone hoses
High-flow air filter
6 drop-in Denso high flow injectors
T-bolt & V-band clamps
Nuts, bolts and fittings
ENGINE AND ACCESSORIES
Fuzion carbon fiber hood
New Turbonetics Turbo Kit w/ Intercooler
New JE turbo nitrous pistons with 8.5:1 Compression Pistons Bore zise 95.50 mm
hks 264 cams
hks springs and Retainer Kit
New JE with Wrist pins and locks
New JE turbo nitrous ring set combination is good for 900HP will handle 40psi of boost or 300 shot of nitrous
New eagle 4340 steel H-Beam Forged Connecting Rods with APR bolts
ACL Rod Bearing 6B26440H
ACL Main Bearing 4M2633H
ACL Thrust 2T2633
Uderdrive unorthodox Aluminum racing pulley set
Unorthodox belts pulley set
FP Stage II Shortblock Assembly (Block Assembly, Machining, Balancing, & Blueprinting)
HKS 97mm Head Gasket
ARP L19 Head Bolts
ARP Main Stud Kit
NGK One Step Colder Plugs
Walbro 255 lph Fuel Pump
CJ Motorsports Stage I Complete Fuel Return System
Nissan Rear Coolant Bypass System
k1 body kit
Exhaust:
Turbonetics 3" inc down pipe
infiniti factory rear exhaust assenbly
Engine Management System:
Turbo XS Utec ECU & boost sensor
Aem True boost controller
Brakes & Suspension:
Tein Monoflex coilovers
Rear upper camber kit
Brembo brakes
Driveline:
ACT RACING STAGE 3 Clutch
ACT Racing prolight 13lb flywheel
ATS Carbon 1.5 Full Locking Rear Differential
BBS style Racing 19" Mercury Silver 9.0 GTS Front Wheels
BBS style Racing 19" Mercury Silver 10.5 GTS Rear Wheels
Pirelis Tires: Front (255/35ZR19) - Rear (285/35ZR19)
Stereo
Infiniti G35 BOSE 6 CD changer Radio System
Factory navigation DVD player
Car is a blast to drive and its really smooth, ice cold air, check engine light is on because of cats missing. Everything works great. $21,000 OBO
Any questions you can PM me or email me at Bazookasaa@yahoo.com!!!TRADES ARE WELCOMED!!
Old Mar 29, 2009 | 10:44 AM
russianvolta's Avatar
Sorry couldnt find where you are located.
Old Mar 29, 2009 | 01:41 PM
Z33=MONEY's Avatar
orlando FL
Old Mar 30, 2009 | 01:07 AM
mitsuman's Avatar
nice car man. hey straight trade for mine! haha
Old Mar 30, 2009 | 08:23 AM
Z33=MONEY's Avatar
tttttt
vmcarbuyer
Oct 12, 2019 12:42 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
ClwMike
Jul 23, 2015 12:55 PM
vstypicals
Jul 20, 2015 10:55 PM
Chattzx
Jul 17, 2015 11:23 AM
