*IP's*
Old Sep 5, 2012 | 01:27 AM
  #3631
DrewDrew's Avatar
LALALALALALA.
Old Sep 5, 2012 | 04:54 PM
  #3632
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Loving it, Drew. Gold and IP is one of my favorite combinations.
I also like how your wheel specs aren't crazy aggressive, but just good enough to still be flush with the fenders and look good.
Old Sep 5, 2012 | 05:13 PM
  #3633
Drew113's Avatar
Ban Hammer Expert
Drew Drew just wanted to let you know i got my f&r camber kits on and got my alignment and my guy was just BARELY able to get me within specs literally perfect specs for getting me to the limit!! Thanks again to you and blain
Old Sep 5, 2012 | 05:37 PM
  #3634
AzuMaster's Avatar
Originally Posted by ambiguous113
drew drew just wanted to let you know i got my f&r camber kits on and got my alignment and my guy was just barely able to get me within specs :d literally perfect specs for getting me to the limit!! Thanks again to you and blain
pics!!!
Old Sep 5, 2012 | 05:43 PM
  #3635
Frankieg35's Avatar
Did he use the front shim kit??
Old Sep 5, 2012 | 05:45 PM
  #3636
Drew113's Avatar
Ban Hammer Expert
yupp he did use the shims and that is why he was even able to do it haha still overseas right now but i will see if i can get some pics of the after alignment
Old Sep 5, 2012 | 05:51 PM
  #3637
Frankieg35's Avatar
Did he have to use camber bolts in the rear??
Old Sep 5, 2012 | 05:52 PM
  #3638
Drew113's Avatar
Ban Hammer Expert
you mean toe bolts?? yeah he had to elongate the holes to get the toe at zero
Old Sep 5, 2012 | 05:58 PM
  #3639
Frankieg35's Avatar
No camber bolts.. they use the same bolts and elongate the hole for the rear camber arm, gives u 2-3 degrees of camber..
Old Sep 5, 2012 | 05:59 PM
  #3640
Drew113's Avatar
Ban Hammer Expert
He used everything that was included in SPC's front and rear kits
Old Sep 5, 2012 | 06:07 PM
  #3641
Frankieg35's Avatar
Ok so no he didn't.. I guess I'm just lower than u.. Gotta raise mine a lil bit and get in specs to save my tires.. lol
Old Sep 5, 2012 | 08:54 PM
  #3642
VMRWheels's Avatar
Originally Posted by DrewDrew
[IMG]http://www.canibeat.com/wp-content/uploads/2012/08/Infamous_Arthur_39.jpg[IMG]
LALALALALALA.
I saw you driving down SM Parkway this morning.
Car is looking good, as always.
Old Sep 5, 2012 | 09:34 PM
  #3643
TGMcCoy's Avatar
Old Sep 6, 2012 | 01:13 AM
  #3644
DrewDrew's Avatar
good to hear. I based yours off a mixture of Son's T1S specs and my GTS specs.
+2 front on mine was -1.4. +0 on Son's rears were -1.8*. but if you're lower than Son, you may have needed the extra camber to make sure the lip tucked properly.
I expect professional pics when you get back in the states.
thank you Kevin! still need to get my front bushings installed, new rear camber arms, and alignment. I'm flush, not poking tho.
It's actually unacceptably dirty tho. work 6 days a week and class as well - literally have no time to do anything. have to wash it friday after work before Auto Gallery on Saturday. stop by maybe? it's at the HB pier.
Originally Posted by TGMcCoy
[IMG]http://i378.photobucket.com/albums/oo228/Hougard/03%20G35%20Coupe/Picture016.jpg[IMG]
[IMG]http://i378.photobucket.com/albums/oo228/Hougard/03%20G35%20Coupe/Picture017.jpg[IMG]
I think you should hit up Blain/4DGS for help with bump stops on air suspension. It'll stop your suspension travel at an exact point so you can drive lower the way you have your set up (fender resting on wheel lip). your current set up, you have to air up high enough so you don't smack your fenders.
Old Sep 6, 2012 | 01:38 AM
  #3645
TGMcCoy's Avatar
I'm only on stance coils and 5-6* camber in the rear. They clear the fenders, but am getting the rears pulled some more to increase clearance/ or reduce camber
