06 G35 CP Liquid Platinum.Tein Coilover with Work-VSXX
I accidently put the rear as front, but anyways.
Front is the one I DIDN't list (no point listing since I am trying to prove SPC rear camber is not needed on my car, I believe this whole thing started ever sicne i said I DON'T THINK MY REAR CAMBER IS THAT BAD), and I listed Rear left only since the rear right is almost the same.
Just for reference:
The dude who adjusted my alignment does drift cars. They use the the DSP600 hunter alignments machine
Everyone around my area know the guy, he had done over 30+ 350z and G35 alignment's over the years.
Here is there informations:
SPEED FACTORY
18541 E. VALLEY BL
LA PUENTE, CA 91744
626-810-8100 | 626-810-8196
The guy who align my car name is david.
Just for you redlude97
REAR RIGHT
ACTURAL camber -2.6 BEFORE -2.7 SPECIFIED RANGE=-1.9-0.9
ACUTRAL TOE .10 BEFORE .14 SPECIFIED RANGE 0.00-0.22
Just for reference:
SPEED FACTORY
18541 E. VALLEY BL
LA PUENTE, CA 91744
REAR RIGHT
Over all my camber in the rear is .7 degree out of range and toe is fine.
So spending over okay... $270-$300+ to fix .7 degree is it worth it for daily drive? nope.. HELL NO
actually, ideal camber for a street car ~1.1, so a camber kit can fix 1.5 deg of camber for $143. But if you want to leave it you are welcome to do that, its your car afterall, we can only give you suggestions
I tottaly understand, don't get me wrong. (you guys are already alot of help, thanks!) However after I saw the alignment sheet, chatting with the guy who align my car. I just don't think .7 degree out of the SPECIFIED range for a G is worth the $$
Originally Posted by Hexxum001
A little bit of negative camber is not a bad thing mang. I think you are okay just keep your eyes on your tires for uneven wear.
p.s i just got the JP co's lip =)
getting it painted next week
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
