S tech and H tech people lets see em!
Old May 11, 2012 | 06:20 AM
  #526
LiquidREVUP's Avatar
Originally Posted by ddzc
Gents,
With the h-tech z springs...will the rear springmounts need to be modified/chopped in some way in order to match the height of the front? What exactly needs to be done?
Also, I read the z springs are stiffer so will the ride quality be worse running z springs over g springs?
Thanks
Yes tein springs sit higher in the rear than front so springmounts need to be cut to make the drop even. Just search springmount mod and you will find the DIY.
And yes higher spring rate means the ride quality will be more harsh, less comfy, but the car will handle better
I ran z stechs for over a year, it was slightly stiffer but my girlfriend didn't complain. She started complaining when I upgraded to coilovers lol
Old May 18, 2012 | 12:07 PM
  #527
coreydee's Avatar
350z s-tech 245/275, rears rolled
Old May 21, 2012 | 04:40 PM
  #528
sTeadFasT96's Avatar
Lookin' good brother
Old May 22, 2012 | 08:18 PM
  #529
CLEANBS's Avatar
on 350z s techs
Old May 23, 2012 | 01:25 PM
  #530
one2nite's Avatar
looks like im going h techs
Old May 23, 2012 | 04:42 PM
  #531
Jbruckhoff's Avatar
Originally Posted by CLEANBS
on 350z s techs
looks good! what are the specs on the Wedssport's?
Old May 23, 2012 | 08:09 PM
  #532
CLEANBS's Avatar
Thanks
9.5/10.5+15 natural camber for now
Old Jun 13, 2012 | 04:29 PM
  #533
Darkstar752's Avatar
For you guys with 350Z S-techs:
Which camber kits did feel were necessary? Front/rear? Thanks!
Old Jul 6, 2012 | 12:45 PM
  #534
leetillman351's Avatar
I'm on 20s, don't want to buy a full camber kit. What springs? Tanabe, s techs or h techs, g35c
  #535
akoustic's Avatar
I also want to ask the folks that have s-techs if the camber kits were necessary to be be in recommended camber readings.
Old Jul 6, 2012 | 01:21 PM
  #536
irishsig's Avatar
Yes most people with the s-techs need a camber kit to get back into spec.
Especially if u do the rear spring mount mod.
Some guys don't run a kit up front because it is so much more expensive, but it will eventually pay for itself over the years.
BTW...SPCs are a real quality kit for the rears (get the toe bolts too).
Old Jul 11, 2012 | 05:56 PM
  #537
Dcampos662's Avatar
Hey I'm think of putting 350z s techs on my G but to the fit right? Also is there any mods needed for the s techs to fit g 35? Help please
Old Jul 12, 2012 | 12:41 PM
  #538
350z and g35 springs are interchangeable and do not require anything extra to fit.
Old Jul 12, 2012 | 02:28 PM
  #539
Dcampos662's Avatar
So for u that have experienced the 350z s techs how are they ? Or should I stick with the g35 s techs? Want a lower drop but don't want to be to bumpy lol
Old Jul 12, 2012 | 02:40 PM
  #540
irishsig's Avatar
I'd def go with 350Z s-techs.
The reason most people go with the Z and not G stechs is because of better spring rates.
The spring rate of the G stech rears is way too soft, IMO.
It's weaker than oem.
And if your coming from a coupe with oem sport suspension you'll def want the z stechs.
How many miles do you have on the oem shocks?
If you have over 70k then I'd consider swapping out the oem shocks/struts with some tokico HPs when doing the springs.
Very affordeable alternative to other more pricey shock setups, but still good build & performance capabilities.
