dropped her rear and fixed her as* crack
Old Jul 2, 2007 | 07:29 PM
  #31
HXS's Avatar
HXS
Originally Posted by sugsss
u cut the springs for that ,get some coilovers and slam that ****!!!!!
yeah... i'm a cheapo . when my suspension starts to go, i'll definitely get coils.
So to get things straight, you cut the rear springs to lower the rear more? Did you already trim down the springmount 3/4" before you did so?
lol... lude, i knew you'd comment. what happened was that i had cut my springs a quarter coil a while ago and then you came out with the spring-mount mod. so when i wanted to lower more, i just decided to cut more coils than cutting the spring mount (just cuz it was already cut).
so in short, my spring-mount is not cut.
Old Jul 2, 2007 | 07:47 PM
  #32
redlude97's Avatar
I didnt come out with the springmount mod, its been done since I think 03 by some of the OG sedan owners, thats where I got the mod idea from, so it was out way before you cut your springs. A little research would have saved your some time and money. I would highly suggest purchasing a new set of h-techs and cutting the springmount instead so you don't screw up the springrates, especially since you are on nonsport shocks
Old Jul 2, 2007 | 08:08 PM
  #33
g35cali's Avatar
good write up lude def going to do this instead of messing with the springs
https://g35driver.com/forums/brakes-suspension-diy/137046-diy-cutting-rear-springmount-aka-springmount-mod.html
is there a DIY on the actual removal of the springmounts?
also, do u have set available that you have already pre cut?, its worth a shot
tiguy99
Mar 1, 2016 11:42 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Soumilg
Jul 18, 2015 12:33 PM
