Post Up Your Lugs/wheel Combos!
#79
Originally Posted by aHero4Eternity
NeoChro R40
*Kyosho
*Kyosho
I would be concerned about useing those lugs. Someone could use a bolt with a nut on it to loosen your lug nuts. I will try to explain, one could screw a bolt into the lug then take a nut and tighten it up against the your lug. Once the nut is tight enough then all they have to do is just loosen your lugs.
Dont get me wrong I love your setup, but I would hate see you post pics of your ride without wheels. You could just replace your current lugs with shoter ones so that there is no thread inside the lug left exposed.
mine arent as fancey as yours but they will be very hard to remove.
#80
on
Originally Posted by TIRE_SMOKE96
First of all please understand I am only trying to help! You have an awsome setup and I want you to keep it! So please listen to my concerns for you.
Do you know what kind of lug nuts that is? They're Kics Project r40 Neo-Chro. It's made out of cold-forged steel. With your medthods I don't know how you could get a screw and a nut on there? Confusing and a really retarded idea. I'm not saying those lugs are impossible to break, I'm just saying you can't break them with your way.
Also I do want to remind that YOUR lug nuts is the most commonly stripped ones. They sells them on ebay for $15/per set of 20 and the key strips all day long. I used to have 2 sets on my integra. In addition, if you want people to take you seriously, please don't use ADR wheels.
#82
#83
#85
Originally Posted by AlvinHuyN
uUUuUHHHHH.......
#86
I don't want to get in a pissing match but what I think tire smoke was saying was that since it's an open ended lug nut and being so deep that there are threads in the lug nut that are exposed (extended beyond the wheel stud). If this were the case then you could screw a 12x1.25 bolt into the lugnut which would engage in the threads, use another nut as a jam-nut which would in turn lock the bolt to the lug nut. Then you could backout the lug nut from the wheel. That would be easily possible.
Another method would be to use a bolt extractor on the exposed head of the lug nut. Since it's sticking out beyond the face of the wheel there is a lot of room and an extractor could easily be placed over the end of the lugnut. It doesn't matter what the material or shape of the lug nut is, the extractor will simply wedge it's self on the nut and off it comes. The extractor uses sharp flutes which cut into and grip any shaped lugnut as long as there is enough clearance to get it on the end and with the lugs extended this is a good possiblility.
#87
thankyou
#88
on
aHero4Eternity - PMed ya bro Thanks for the help!
TIRE_SMOKE96 - I'm sorry if I made you look bad but if you don't know the lugs, its composition, and you're spreading false info I have the right of correcting that. I was also trying to be nice in stating that your lug strips easily and the fact that I used to have ADR and the quality was crap and I have seen many cracked sets. Not to get any further in this argument you can take my word for what it's worth - or not. It's up to you but I still stand by the fact that the Kics Project lugs can't be broken by your method.
DHCrocks - I understand what the OP is trying to say but considering the material used to make the r40 lugs I doubt he can use that method. Now I did say other methods could work, just not the one he specifically said
#89
