Quote:
I am lowered on BC coils.Originally Posted by beaguilar
Nice. The bigger spacers really helped. I may go that route as well. What are you dropped on again? I forgot.
I dont know what people are talking about when they say BC coils dont lower enough.. I am not even maxed on these things and I still have a good 2 more inches to lower in the rear. The front I believe I have another inch.
Here is a picture of the back
Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
Quote:
What is your camber specs??Originally Posted by Algy
Just recently upgraded my spacers from 20mm fronts to 30mm fronts and 30mm rears to 38rears. Will post pics tonight.
Quote:
Fronts are on the verge of being off factory specs. I believe its -1.3-5ish. The rears are off spec -2.5-6ish.Originally Posted by Frankieg35
Frankieg35
close
- Join DateOct 2006
I'm trying to figure out the biggest spacers I can run on stock camber with just the rear fender lip grinded smooth..
TGMcCoy
close
- Join DateMar 2004
- LocationPortland, Oregon
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:95 Times in 88 Posts
Quote:
What size spacers do you have now and how much room to your fender is left?Originally Posted by Frankieg35
Quote:
Damn those chrome 19s are looking very nice on your G. Originally Posted by beaguilar
What spacers are you running?
Quote:
40+ easy. I had 38mm and that wasn't super flush and and camber was -3.1. The stock camber can be adjusted more into the negative.Originally Posted by Frankieg35
Thanks man. I'm on 25 f/r. May go up to 30/38 if I don't get some wheels by this summer. Planning on dropping the rear a bit more so itll be even with the front once I roll the fenders. Didn't get the chance today.Originally Posted by Algy
Damn those chrome 19s are looking very nice on your G. What spacers are you running?
I would say a 20f and 30r setup would fit you nicely frankie.
If you go any bigger in the rears, youre going to have to run some negative camber. 30mm should get you close to stock specs in the rear. 20mm on the fronts should be fine with stock specs. 25mm might be close to stock specs.
Ive played with all sorts of sizes already but then again my rear fenders are rolled.
Frankieg35
close
- Join DateOct 2006
I'm running 30/35 now with a little over -2 camber.. Plan is to put the 30 on the rear and get 20/25 for the front.. Gonna raise my car some too, I'm tucking 35 series tires and my undercarriage hates me for it..Originally Posted by Algy
I would say a 20f and 30r setup would fit you nicely frankie. If you go any bigger in the rears, youre going to have to run some negative camber. 30mm should get you close to stock specs in the rear. 20mm on the fronts should be fine with stock specs. 25mm might be close to stock specs.
