Oem 19's Appreciation Pic Post
Nice Setup...Like that front lip.....Is that the Chargespeed Bottom line Front lip...?
Had to take off my 30mm spacers on the front. It was rubbing way too much on the inner liner I think or maybe the fender.. Not to sure but I think it's the inner fender. Went ahead and put on 25mm in the front.
Question, is there anyone running 30s up front with no issues? Mind you I'm barely on the verge from being off Orem camber specs and I'm running the original tire profile for the Orem 19s (225,40,19s)
Wow... that is just cleaaaaaaan!
Is this yours frankie??? I think this is the first time I have ever seen pictures of your car.
What kind of camber are you running all around to be pushing 30/35mm spacers?
Also what camber arms do you have for the rear and front?
Thanks algy, its mine.. I need another alignment since i raised it but it was a little over 2 degrees of camber.. The front fenders are pulled and my rear fender lip is grinded smooth from my old wheel setup.. I have spc camber kits.. I have another set of oem front fenders that arent pulled that im going to be putting on.. My goal is to run oem alignment specs with smaller spacers but stay flush as i can..
