Old Dec 6, 2010 | 02:19 PM
  #17866
Matzo Ball's Avatar
GGG-G35's
Old Dec 6, 2010 | 02:21 PM
  #17867
The Stimulation's Avatar
Sedan doesn't belong here....just messin around Chris. Car really does look great, both in pics and in person. 11's on a sedan representin'....ooooh yeah.
Old Dec 6, 2010 | 02:33 PM
  #17868
erklep's Avatar
I vote for dre as a staff member!! All in favor say I!!
Old Dec 6, 2010 | 03:46 PM
  #17869
ShanesG's Avatar
No!
Old Dec 6, 2010 | 04:25 PM
  #17870
VictoriousG's Avatar
too clean on that G sedan
Old Dec 6, 2010 | 04:38 PM
  #17871
eurodre's Avatar
shane doesn't want me as staff cus he knows I would ban him
Old Dec 6, 2010 | 05:18 PM
  #17872
ATL_Red_G35's Avatar
Got a Question for the experts on here:
So if I can run 20x10+8 in the front with a 20mm, would that make that I can "almost" run 20x11-5?
The reason I'm asking is that without the spacers, mine would look "sunk". With 20mm spacer, it'd look almost perfect. And my option is to get larger outer lip which can push it 1" further out, thus making it 20x11 at -5 offsets I believe. Given that I'd still be running same tire size (at 235-30) at super stretch mode, it'd clear?
Practical or not? Please advise. Thanks
I've got SPL front camber kit so I can either go 0.5" to 20x10.5+2 with less camber or as said above.
Old Dec 6, 2010 | 05:30 PM
  #17873
If you throw on 20mm spacers you'd be at a 20x10.5 -12. Thus, it would be like running a 20x11 +0. If you want a 20x11 -5, you'd need a 25mm spacer.
Old Dec 6, 2010 | 05:32 PM
  #17874
erklep's Avatar
that wrx is pretty! dude still hasnt gotten around to getting matching wheels though huh
Old Dec 6, 2010 | 05:33 PM
  #17875
eurodre's Avatar
is this going to be for the front or rear?
Old Dec 6, 2010 | 05:36 PM
  #17876
Correct, I'd have a lil room on the 20mm spacer, that's why I figure an extra 5mm wouldn't hurt (or so I thought :P). Plus, I can only get the outer lips either at 0.5 or 1" extension, so that's why.
This is for the front
Old Dec 6, 2010 | 05:48 PM
  #17877
eurodre's Avatar
eh 11 in the front with that kind of stretch isn't really optimal I mean you can do it but at the end of the day the same kind of look and lip size can be got with a smaller width wheel like a 10 with less than half the trouble and no need to do a stupid stretch
thats just my opinion but to each their own, just work around with camber and fender work and it will fit in
you got the right idea on the numbers you posted (every .5" bigger lip= 6mm off the offset)
Old Dec 6, 2010 | 05:58 PM
  #17878
Matzo Ball's Avatar
is that Subi static or bagged?
Old Dec 6, 2010 | 06:03 PM
  #17879
erklep's Avatar
static IIRC
Old Dec 6, 2010 | 06:11 PM
  #17880
Absolutely understandable. But getting just the outer lips would be the cheapest method. Otherwise, I'd got totally different set of barrel to maintain the width and lesser offsets.
Just throwing ideas out there. Might run slightly fatter tires & 0 camber to make up for the "sunkness" feel and look
