Old Mar 28, 2011 | 01:51 AM
  #22591
4DGS's Avatar
It will handle weird, but who really cares about handling anymore lol
Old Mar 28, 2011 | 01:55 AM
  #22592
Adon's Avatar
Originally Posted by ShanesG
+1 like Adon did.
Panda style headlights FTW buddy!
i'm trying to get my front bumper to this actual height in the pic below, i need another inch, so would dropping from 35 series to 30 give me like half inch to an inch maybe ? i already maxed out on coils, if i adjust any lower the fender would be rubbing in the lip over dips
i'm thinking from 255/35 down to 235/30
Old Mar 28, 2011 | 02:36 AM
  #22593
SteveBlake's Avatar
will it really?? cuz since the stock 18's were the same width i didnt think that would be an issue
Old Mar 28, 2011 | 09:35 AM
  #22594
Matzo Ball's Avatar
Adon, I think a 235/35 up front and 275/35 rear (or even 265/30) would give you the drop you need, elinimate rubbing, and still be a decent stretch.
Old Mar 28, 2011 | 09:37 AM
  #22595
Matzo Ball's Avatar
Running an aggressive stretch on the front like a 225 with a moderate stretch on the rear would look retarded.
Blain,
if I were to run 19x10 +20 all around, would a 245/35 meet my needs? Remember, I am not completely slammed (.5 finger gap max all around) and natural camber up front (no arms like in the rear).
What front fender work would be needed? I cannot ride full stiff due to kiddos.
oh...and to stay true to a pic thread.....
Old Mar 28, 2011 | 11:30 AM
  #22596
CandlestickPark's Avatar
ill Sedan
Old Mar 28, 2011 | 12:01 PM
  #22597
Matzo Ball's Avatar
oh damn!
Old Mar 28, 2011 | 12:56 PM
  #22598
The Stimulation's Avatar
Old Mar 28, 2011 | 01:00 PM
  #22599
Matzo Ball's Avatar
Old Mar 28, 2011 | 03:48 PM
  #22600
4DGS's Avatar
The front being so wide would change handling. The stocks are so thin that it really wouldn't make a difference. Also keep in mind, even on the 18" non staggered wheels, the tires are staggered 20mm (225/245)
Originally Posted by Matzo Ball Soup
Blain,
What would you run in the rear?
Look at it like this, this is equal to +17 on a 10. Totally stock front fender.
I'd run a little more stretch than the 245 (235) and you'll need a phone book pull or a moderate pull to clear the fender and not rub on turns.
But that offset wouldn't be an issue.
Old Mar 28, 2011 | 05:23 PM
  #22601
Matzo Ball's Avatar
I would run a square set up front to back. So 235/35 front and rear along with phonebook pull up front?
Old Mar 28, 2011 | 05:39 PM
  #22602
litoflow's Avatar
that Miata and S2k are on point!!
Old Mar 28, 2011 | 06:13 PM
  #22603
Phil DeVtec's Avatar
That white LS is ridic...
Old Mar 28, 2011 | 06:17 PM
  #22604
4DGS's Avatar
Depends how much natural camber your car pulled when you lowered it, everyones seems to be different...
You'd probably be fine just pinching the front fenders and letting the camber go.
Levon was running 10.5 with a 235/30 and 0 offset and he was pinched flat with a really light pull I believe, but his camber was like -5... so add 15mm in lessened camber to that and then the 6mm to convert to a 10" wide wheel.
I started thinking out loud writing that lol
Yea you'll be fine with a +20. If you're going square though, I'd run a 245/35 all around.
Old Mar 28, 2011 | 06:40 PM
  #22605
Yeah I had my fenders pinched with the fender finisher. It gave it a slight pull on its own. Camber was at -5.5. I actually was tucking too with that fender by about 10mm. My other fender that had a roll was more flush but wasn't as even.
