Old Jul 1, 2011 | 11:48 PM
  #25666
eurodre's Avatar
do you need more negative camber?
Old Jul 1, 2011 | 11:50 PM
  #25667
xXHotelCrazyXx's Avatar
camber what you need, not what you want
Old Jul 1, 2011 | 11:52 PM
  #25668
CandlestickPark's Avatar
ill Sedan
Camber is only going to make it look tucked, unless you add a spacer.
Old Jul 1, 2011 | 11:53 PM
  #25669
illest G's Avatar
yes, because i plan on dropping it a little bit lower.
Old Jul 1, 2011 | 11:58 PM
  #25670
illest G's Avatar
i considered spacers but i was told that my fenders would rub too much and wen i said roll those ****ers people would tell me my paint would crack. so im still tryin to figure it out.
Old Jul 1, 2011 | 11:59 PM
  #25671
ill Sedan
^Your fenders haven't been rolled yet? Gotta do that man. The paint more than likely will not crack if the person who does your fender work knows what they are doing. Use a fender finisher to pinch the fronts (remove screws, clips and debris from inside the fender liner first).
Old Jul 2, 2011 | 12:03 AM
  #25672
antknee's Avatar
Woah how did u make ur rear wheels fit if your fenders are not rolled?
More pics of your car please
Old Jul 2, 2011 | 12:09 AM
  #25673
illest G's Avatar
no, rear fenders are rolled. mybad, i should have said that earlier. problem is that i dont want the 'tucked look. i want the fender to look like it sets on the lip.
Old Jul 2, 2011 | 12:12 AM
  #25674
Wilg35j's Avatar
Eurodre always talking ****, wish he drove around here with his precious stance...with his tight *** shirts
Old Jul 2, 2011 | 12:21 AM
  #25675
iiiiiekoiiiii's Avatar
Sedan definitely is rocking the right offsets. But he has an X and can't slam his ride without banging everything even on tiny dips. Would look better if it was lower IMO. I'd also prefer a 35 series vs 40 series tire up front on that setup but then that would throw the AWD system off.
thanx bro, u alrdy know the deal with the Xs. Sucks slammed on 19s. going to try 20s next.
lawlz
Old Jul 2, 2011 | 12:24 AM
  #25676
ill Sedan
Old Jul 2, 2011 | 12:34 AM
  #25677
Johnmikins's Avatar
Let me join in...
Old Jul 2, 2011 | 12:48 AM
  #25678
ShanesG's Avatar
+1111111 on more fitted g's
Old Jul 2, 2011 | 01:36 AM
  #25679
Dranom's Avatar
wheres DRE at?
Old Jul 2, 2011 | 01:49 AM
  #25680
JBF's Avatar
JBF
Originally Posted by Dranom
wheres DRE at?
